Thread: Time to refresh tired suspension! Suggestions?
Results 1 to 20 of 22
  1. #1 Time to refresh tired suspension! Suggestions?
    Sep 2011
    Logansport, IN
    So, after putting some weight in the 98 GP's trunk this weekend, I realized just how shot the stock struts and springs are. Gonna start with new struts and springs, and probably do sway bars while I am at it. I am not necessarily looking to get crazy aggressive, but definitely want to tighten up the stock suspension a good bit. Looking at about a $800 budget, and the struts definetely gotta go. I can pick up the KYB quickstruts for about the same price as the Monroe,($125 each), so what is everybodys thoughts? Does anybody know if the KYB quickstruts are any good?
  2. #2 Re: Time to refresh tired suspension! Suggestions?
    Ocala, FL
    Kyb gr-2(or excel-g) is an excellent stock replacement. As long as their quickstrut uses that it's probably good.
    I would say one of the best thing to freshen suspension is replacing your control arms, and they're relatively cheap if you're doing the work yourself.
    Also get under the car and look for worn bushings, if you do sway bar also get some new endlinks.
  3. #3 Re: Time to refresh tired suspension! Suggestions?
    Sep 2011
    Logansport, IN
    awesome, thanks! any recommendations on which swaybars? I was thinking the GMPP bar from ZZP
  4. #4 Re: Time to refresh tired suspension! Suggestions?
    MA
    Jump to page 6 http://www.grandprixforums.net/silva...t-6-41118.html
    That is what I'll be doing. I forget what my total $
    SMGPFC Member #9
  5. #5 Re: Time to refresh tired suspension! Suggestions?
    honestly for what you're doing you might as well throw some mild lowering springs on the car while you're at it.
  6. #6 Re: Time to refresh tired suspension! Suggestions?
    Sep 2011
    Logansport, IN
    Any recommendations on lowering springs besides Eibach? It kinda sucks that I work for one of the top racing spring companies in the world, but we have absolutely nothing that will fit without retrofitting the struts to coilovers! Does anyone know who manufactures the DNA Motoring kit or the SCC kit? I know enough abouth the Eibach springs to know there is not really any testing/engineering behind their lowering springs, they just figure a drop and increase the spring rate, based on the stock spring rate, which may tighten up the suspension, but doesn't necessarily help the overall balance of the car any. BTW I live in north central Indiana, and this car is my DD so I can't go too low, since we have to drive through up to 6 inches of snow at times.
  7. #7 Re: Time to refresh tired suspension! Suggestions?
    Sep 2011
    Logansport, IN
    Going to get a new "high flow"(read:hollow) cat and u-bend delete done today, already had to replace the resonator with a glass pack and have a sneaky feeling the stock cat is partially plugged, which is causing me to only get 14 mpg, even when I drive like a grandma, and occasionally throw a P0301 code, and I have changed plugs, wires, coil packs, injectors, etc, it only seems to throw the code after a long drive or if I am beating the hell out of it and it gets nice and hot. When it throws the code the idle gets a little rough also, but nevers dies and as soon as I get on the gas the miss goes away.
  8. #8 Re: Time to refresh tired suspension! Suggestions?
    Ocala, FL
    I run ssc lowering springs, I'm happy with them..
    Also on sway bars, I went with gmpp.. Found the best deal through summit racing
  9. #9 Re: Time to refresh tired suspension! Suggestions?
    Jan 2009
    Tallahassee, FL
    GMPP swaybars, Vogtland springs, GR-2 struts, and some UMI rear control arms. That should tighten up the suspension, be fun, and still ride nice. My suspension is a little more aggressive with Eibachs but I wouldn't have it any other way.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  10. #10 Re: Time to refresh tired suspension! Suggestions?
    Mullet Member Wotgtp's Avatar
    Connecticut
    I have a gmpp kit and vogland springs, just waiting on wbody store to send KYB gr2 Struts and accessories to install on my car. I will let you know how it turns out when I put them in. The members I've seen with them like the Handling characteristics of said parts which is why I decided to get them.
  11. #11 Re: Time to refresh tired suspension! Suggestions?
    Donating User Odi's Avatar
    Chicago South Suburbs
    GM Parts Direct: Your direct source for Genuine GM Parts gmpp kit. i think this is the cheapest around.
    right now im on fresh suspension, pretty much everything replaced other than lateral arms. for the drop i got ssc springs w/ agx shocks. i do like the shocks so far, adjustment is quite handy.
  12. #12 Re: Time to refresh tired suspension! Suggestions?
    Jan 2009
    Tallahassee, FL
    Get some good lateral arms, it's an awesome way to finish off any suspension. I <3 my UMIs
    77 Morris Garage B
  13. #13 Re: Time to refresh tired suspension! Suggestions?
    Ocala, FL
    Quote Originally Posted by Sandman View Post
    UMI makes lateral arms?
    Hmm I their trailing arms I did not know they made lateral arms though.
  14. #14 Re: Time to refresh tired suspension! Suggestions?
    Lateral arms help the rear end that much?
    My rear end is quite loose at the moment.
    Even with an addco sway bar, vogtlands, bilsteins and GMPP trailing arms.
  15. #15 Re: Time to refresh tired suspension! Suggestions?
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by codyAK View Post
    Control arms, whoops
    I could feel the difference on slower turns, they do quite a bit with helping the tires stay in place.
    77 Morris Garage B
  16. #16 Re: Time to refresh tired suspension! Suggestions?
    Slower turns?
    I'm talking right before the tires give out, rear end feels sloppy.
    Could be my low rolling resistance 16's though...
    Nevermind, you're talking about trailing arms
  17. #17 Re: Time to refresh tired suspension! Suggestions?
    Jan 2009
    Tallahassee, FL
    Or those whatever they're called lol
    I'm just saying you can feel the difference even on slower turns it's that much of a difference. I have gotten my car a little slideways before by accident. They are well worth the $110, turns can be taken much faster.
    77 Morris Garage B
  18. #18 Re: Time to refresh tired suspension! Suggestions?
    Dec 2010
    Racine WI
    I'm in the same place... tired suspension, but not looking to drop lots of $$ into this. It's a DD with usually me in the car, maybe 2 small kids. No heavy loads, etc.
    Would love a comprehensive parts list of a modest replacement. I'm ok with something a bit better than stock, but not looking to go autocross the car.
  19. #19 Re: Time to refresh tired suspension! Suggestions?
    buy KYB complete struts.
    Dorman/moog LCA's.
    moog outer tie rods.
    moog sway bar links and bushings all around.
    that should take care of most of it.
  20. #20 Re: Time to refresh tired suspension! Suggestions?
    Dec 2010
    Racine WI
    how much should I expect to pay for all that? doing the work myself.
  1. The Silva bullet... he actually did something to his car!
    By SilvaMan61 in forum Members Rides
    Last Post: 07-13-2012, 08:53 AM
  2. Suspension Refresh
    By montecarlo01ss in forum Brakes/Suspension/Chassis
    Last Post: 05-16-2011, 01:04 PM
  3. suspension makeover. opinions and suggestions plz.
    By gtpinsc in forum Brakes/Suspension/Chassis
    Last Post: 01-24-2011, 05:37 PM
  4. Suspension suggestions
    By travon802 in forum Brakes/Suspension/Chassis
    Last Post: 05-25-2009, 02:12 PM
  5. 150K suspension refresh
    By Smokin2000gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 08:14 PM
