Thread: Monte Carlo Cross Bars....
Results 1 to 20 of 29
  1. #1 Monte Carlo Cross Bars....
    Donating Users crock's Avatar
    Traverse City, Michigan
    Got these off of a monte the other day. They are thicker then the usual grand prix ones. I thought they may be a good upgrade for the $12 I got them for. I also have gmpp strut tower bars but I need to order brackets.
    Think it will help anything at all?
    99 GTP- 104s, 180 Tstat, 1.9 rockers, 3.4, ls1 MAF, KN, 3''DP, HF cat, GMPP Strut Bars, Crappy Tune, Broken Tensioner Mod.
  2. #2 Re: Monte Carlo Cross Bars....
    Those actually do nothing to brace the chassis...in fact their purpose is to bend when your in a frontal impact...so the hood doesn't come back and decapitate you.
  3. #3 Re: Monte Carlo Cross Bars....
    ok well well well i thought they were cool. lol. then why do they make aftermarket ones? Just for looks?
  4. #4 Re: Monte Carlo Cross Bars....
    PA
    Quote Originally Posted by crock View Post
    Yup, just for looks.
    2001 GSE
  5. #5 Re: Monte Carlo Cross Bars....
    Well they look better then the flat ones, imo. But to each his own. lol
  6. #6 Re: Monte Carlo Cross Bars....
    PA
    Yeah, a lot will agree with ya. And IMO, it is better to put stock bars on there from a MC than go to the solid billet ones they sell. Like blue said, they are intended to push the hood up and make it buckle in the middle instead of sliding right back through the windshield and cutting your head off in an accident. I would rather my engine bay not look as nice and keep my head.
    But I can hear it now.
    "Wow that's a terrible accident. The driver of that Grand Prix lost his head. But damn, those are nice engine braces! "
    2001 GSE
  7. #7 Re: Monte Carlo Cross Bars....
    You sure about that Blue?
    Since many of the other GM FWD cars don't have them, it's more likely that they are there to steady the radiator support from pulling backwards when you torque the engine. All the other bodies that don't have them, have mounts to the subframe only and not to the radiator support.
  8. #8 Re: Monte Carlo Cross Bars....
    Check the specs of the accidents...sure of it. Which is why every frontal GP collision you see...the hood bends right in two.
    Not saying they serve more than one purpose, but that is the main aspect of things. Also, other GM FWD body's are different...and have different crumple zones...such as the H and J Bodies...
  9. #9 Re: Monte Carlo Cross Bars....
    so zef your saying i should put the stock ones back on instead of keeping those? Will the MC bars still bend the hood?
  10. #10 Re: Monte Carlo Cross Bars....
    Not sure I'm buying it..
    H is called H for "huge" crumple zone!
  11. #11 Re: Monte Carlo Cross Bars....
    PA
    No, I think any stock GM cross braces like that will be fine.
    2001 GSE
  12. #12 Re: Monte Carlo Cross Bars....
    cause on the back of the bars, theres a part that they are bent. so im assuming its so they will bend as well and then bend the hood. also just ordered my Don Rome brackets!
  13. #13 Re: Monte Carlo Cross Bars....
    Which is why W stands for Whimpy.
    Whimpy crumple zones.
  14. #14 Re: Monte Carlo Cross Bars....
    Wimpy
    Huge
    Ginormous
    Crappy
  15. #15 Re: Monte Carlo Cross Bars....
    HUDSON
    I thought the braces were put there so you would have a place to rest your elbows while working under the hood.
  16. #16 Re: Monte Carlo Cross Bars....
    wow. Really? I thought they were for my wrenches.
  17. #17 Re: Monte Carlo Cross Bars....
    HUDSON
    NOpe, the MC ones won't hold wrenches, the GP ones do double as wrench holder/elbow rest.
  18. #18 Re: Monte Carlo Cross Bars....
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    So because I have the zzp ones my heads gonna get chopped off? I don't think I'm buying it either... Bills reason actually makes sense, and well them being there to fold the hood doesn't. I've seen soooo many Grand Prixs with front end damage down at pullapart and the hoods all folded just fine without any assistance from the diag braces pushing them up. And how is the hood just gonna slide back and cut a head off? Its locked with the latch in the front and out of all the folded hoods and front end wrecks I've seen of these and many other cars I've never seen a hinge shear the pivot pin.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  19. #19 Re: Monte Carlo Cross Bars....
    Quote Originally Posted by QUICKSILVER462 View Post
    I meant the GP ones lol. and in my wreck they didnt bend.. il post pics....
    My bar is still straight if you can see it...
  20. #20 Re: Monte Carlo Cross Bars....
    Guys ...I started as an H body owner. We were jealous of the upper motor mounts etc and some engineering folks looked at the bars. To add upper mounts, I'd have to have added some bracing. The mid 90's Caddies had a small angle brace as well.
    Then I realized that with my slightly modded front mount that I had less movement than a fully poly'd engine. No thanks..no need for that upper get in the way mounting system.
  1. any monte carlo?
    By nemesis in forum Chevrolet Monte Carlo
    Last Post: 01-09-2015, 01:43 AM
  2. Can you drive without cross bars (fender support bars) for a short tiem?
    By Hippo Machine in forum Visual/Body Modifications
    Last Post: 06-29-2011, 10:47 PM
  3. Painting Cross Bars (Fender Support Bars)
    Last Post: 06-29-2011, 10:05 PM
  4. GP vs. Monte Carlo (SS?)
    By Deimos in forum Track Sessions and Kills
    Last Post: 03-26-2010, 12:02 PM
  5. monte carlo/impala sway bars vs grand prix
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 11-07-2008, 10:34 PM
