Thread: Correct tie rod nut?
Results 1 to 7 of 7
  1. #1 Correct tie rod nut?
    SE Level Member Lionel's Avatar
    Moncton N.B.
    I'm trying to remove my outer tie rod from the knuckle and I seem to remember them having crown shaped nuts with a cotter pin through them. this one has a nylon nut, and i cant for the life of me remove it.
    I put a 8mm socket at the end of the stud and used a wrench to turn it as far as it would go, now its stuck and the bottom where the 8mm socket goes is stripped.
    How does 1 uplaod a photo anyway? i converted it to bmp, then i resized it so it was 194kb's then it tells me I've exceeded my quota by 52 kb's
    I had a nice pic to show.
    thanks death punch
  2. #2 Re: Correct tie rod nut?
    upload to a photo sharing website like photobucket and link the DIRECT LINK code.
  3. #3 Re: Correct tie rod nut?
    Feb 2010
    TN
    Quote Originally Posted by Lionel View Post
    thanks death punch
    That is the original factory nut usually they pop right off however in your case that is not so I have attached a link for a tool I have y=used on some pretty nasty nuts even in the junk yard this tol is worth its weight in gold
    Buy Irwin Bolt Out with Case 394001 at Advance Auto Parts
  4. #4 Re: Correct tie rod nut?
    Moncton N.B.
    that tool would really come in handy,
    but in my case the nut is still good, its the bolt that is turning with the nut. what i stripped is the bottom of the bolt where you would put an 8mm socket to stop the bolt from turning. but at this point theres almost nothing left to put the socket into
    and i dont want to put vice grips above the nut cuz then I'll ruin the threads.
  5. #5 Re: Correct tie rod nut?
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  6. #6 Re: Correct tie rod nut?
    Charles City, IA
    Torch out get a long bar and push down on the top of the tie rod while some one trys to spin the nut.
    SMGPFC Two Nipple General
  7. #7 Re: Correct tie rod nut?
    18mm wrench + that looping wrench trick.
    should pop it loose.
    What may happen is the joint spins in the tie rod...
    then its cuttin' time.
    Unless you get it far enough off that you can get vice grips between the top of the knuckle and the top of the tie rod.
  1. Correct PS Fluid?
    By FriboRage in forum General Tech Discussion
    Last Post: 05-25-2010, 09:18 PM
  2. to disable drl the correct way?
    By raymondtrudeau in forum Visual/Body Modifications
    Last Post: 10-18-2009, 09:27 PM
  3. cant seem to run the 'correct' afr
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 11:24 AM
  4. Is this how to correct?
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-19-2009, 01:52 PM
  5. Am I correct?
    By Bogers99GTP in forum Off Topic Discussion
    Last Post: 09-08-2008, 08:25 PM
