Thread: Are Ceramic Pads the way to Go?
Results 1 to 10 of 10
  1. #1 Are Ceramic Pads the way to Go?
    GT Level Member adidasdude1061's Avatar
    Jul 2008
    P-Town, MN
    I have R1 semi mettalics along with the E-Line R1 rotors, and the backs aren't bad at all, but the fronts squeak and grind and leave dust. How are the posi-quiet Ceramic pads? I know I have no problems with my calipers, and I tried anti squeak stuff, so I don't know what to do.
    '97 BLACK GTP--Chrome K&N CAI--3.5" MPS--3" RT Cat Downpipe--180*Tstat--Tuned PCM--Alpine 9886--Kicker Amp - 2 12" Kicker L7's--ALT boost&rewire
  2. #2 Re: Are Ceramic Pads the way to Go?
    St. Louis Mo.
    Go with the Ceramic Posi's. I think I sent you a link on one of your other posts. They are worth it and will not cost you an arm and a leg in the process.
    James Shafer
    St. Louis MO
  3. #3 Re: Are Ceramic Pads the way to Go?
    your moms house
    i have ceramics, like em, they are quiet and almost dust free. rarely get brake dust on my rims.
  4. #4 Re: Are Ceramic Pads the way to Go?
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    I ordered from R1 and they tried to give me the half ceramic half metallic. They said they were out of the ceramic. I asked when they would get the cermaics in, and i ordered them when they did
    That's 2 horror storys I have heard from half metallic half ceramic brakes...
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  5. #5 Re: Are Ceramic Pads the way to Go?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Napa stores have a pad they sell now called an Adaptive-1 pad. The inner and outer pads are different compounds and work very well. I have used several sets and have been pleased with them so far. I always like ceramics for the low dust and noise qualities but they dont seem to have the bite that other pads have and I see way too many warped rotors on cars / w-body cars because a lot of heat is created in effort to stop at high speeds.
  6. #6 Re: Are Ceramic Pads the way to Go?
    Jul 2008
    P-Town, MN
    Thanks, I will probably try those for my next set of pads then.
  7. #7 Re: Are Ceramic Pads the way to Go?
    Jul 2008
    P-Town, MN
    Quote Originally Posted by Trannyman95 View Post
    Yours don't squeak or dust then? Do you have drilled and slotted rotors? I just don't need to deal with the squeaking and dust its driving me crazy.
  8. #8 Re: Are Ceramic Pads the way to Go?
    GT Level Member njbrain's Avatar
    Rhinelander WI
    I like Wagner Thermoquiet pads. They are not ceramic, but are quiet and dust free, and hold up very well. Just my two cents.
  9. #9 Re: Are Ceramic Pads the way to Go?
    Fort Wayne, IN
    The Wagner pads are also good pads and i have used a few of those over the past few years with good results. The key to ANY pad to being quite is proper assembly regardless of the material. Make sure the pins are clean with good lube on them, make sure the shims are clean and put a small amount of the lube on them where the pad rides, some pads come with lube and others dont and in this case you can use Sil-glide lube that Napa sells and works very well. Any moving surface on the pad needs lube, a squeal is a high frequency vibration and keeping things smooth, lubed, and clean really helps prevent noise. Most pads have anti-squeal shims already on them to help out. Some pads are pretty picky on rotor surface as to break in also but most pads have a fairly rough starting surface to speed this up. The adaptive-1 pads I have used have not given me any noise or dust problems and brake feel is a little better than ceramics IMO. Ceramics do a great job of stying quite and keeping down dust but the are very hard pads and they just dont have the bite that other pads have, though I still like using them for the benifits.
  10. #10 Re: Are Ceramic Pads the way to Go?
    Bartlett, IL
    Word.
    How To: E-Brake Pwn
  1. Is this a good deal? Rotors and Pads
    By Freebeer187 in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2008, 08:34 PM
  2. Pads for R1 Concepts
    By J_Man55 in forum Brakes/Suspension/Chassis
    Last Post: 06-27-2008, 08:50 AM
  3. Cheap rotors/pads from Ebay(R1 Concepts)... You opinion is requested!!
    Last Post: 06-26-2008, 10:07 AM
  4. Centric pads and rotors. good?
    By 04CompG in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2008, 03:44 PM
  5. Ceramic coating
    By UR LOSN in forum General Tech Discussion
    Last Post: 02-20-2008, 03:56 PM
