Thread: brakes sticking?
Results 1 to 4 of 4
  1. #1 brakes sticking?
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    So I had both brake lines replaced to the rear of the car after it busted.. after it was repaired my left rear brake was sticking because one time I saw smoke and other times I felt the car bogging down...
    So I brought the car in and they replaced the brake hose to the caliper... they said the caliper was fine as they tested it.. now I stil am noticing excessive brake dust on the same wheel plus I think I can still feel it sticking....
    Any idea?
  2. #2 Re: brakes sticking?
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    I would get one of those laser thermometer things and shoot the rotor surface right after a good drive and check for abnormally different readings in temps from the known good one to the suspected bad one. Kinda hard to tell if you have a light grabber sometimes other than waiting a few thousand miles to check for wear differences. I've seen on a mid 90's chevy pickup where the rubber hose to the caliper had a little rubber piece sticking out into the hose and it acted as a 1 way valve and held pressure on the brakes for too long til the pressure bled off, but that shouldn't be your problem since that's been replaced. Could be sticking e-brake cable but I wouldn't expect you to see abnormal brake dust from that, it would vent from the backside of the rotor or is usually just trapped inside the rotor.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  3. #3 Re: brakes sticking?
    Nov 2009
    chicago
    I know it has to be sticking.. I washed the car yesterday and when I got home from work today the rim was completly covered in brake dust... the other 3 wheels were clean.. do I need a new caliper? I just put them on about 2 years ago..
  4. #4 Re: brakes sticking?
    i would think so.
  1. Doors sticking shut
    By oklahoman in forum General Tech Discussion
    Last Post: 01-19-2011, 09:39 PM
  2. 1st gear sticking
    By tayl5645 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-13-2010, 12:34 PM
  3. Help With Sticking Sun Roof
    By Zilcho in forum General Tech Discussion
    Last Post: 08-21-2009, 06:06 PM
  4. Sunroof Sticking
    By streetsmart in forum General Tech Discussion
    Last Post: 06-27-2009, 01:04 PM
  5. Gas Pedal Sticking
    By J_Man55 in forum General Tech Discussion
    Last Post: 06-29-2008, 09:53 PM
