Thread: 98 GS 4T65E fixed alignment Q
Results 1 to 13 of 13
  1. #1 98 GS 4T65E fixed alignment Q
    Donating Users scgonzo's Avatar
    oregon
    Thanks to this forum and others the trans is now spot on.I bought this 98 SC regal with 157k mi. runs awesome bought cheap do to trans when warm would shudder at launch and at WOT it would surge like a clutch pack coming on and off.Serviced it first added lucas,put 300mi no change.Ordered a force motor,finally got around to doing it,it went 2-4-6,had the frame swung out of the way was able to get cover off and back on with no problem.Also replace engine pan gasket, was easy with stuff out of the way.Took 6.5 hrs for all, not counting cleaning tools and floor.Having a rack made it easy.No leaks and trans is perfect.Ive been beating on it hard and no issues.One question I have for the pros,my steering wheel is off center by just a hair to the left.Does someone know if a loosened the frame bolts and made a slight tweek to bring steering wheel to center which way should I try to move it?hope what im asking makes sense.going down the road the wheel maybe off center 1/2 inch,it was perfect before.Thanks for this awesome forum.Gnz,and no im not taking it in to set the toe.
  2. #2 Re: 98 GS 4T65E fixed alignment Q
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Yes, if you loosen the cradle bolts, the cradle will shift a little. You might get away with playing with it. However, an alignment is the only way to know.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  3. #3 Re: 98 GS 4T65E fixed alignment Q
    oregon
    I know thats all it will take to correct it,do you know with all 4 bolts loose,should i pull or pry the front to the left or the right? then tighten
    based on rear wheel drive cars you would adjust the toe the same direction it is off to center.
  4. #4 Alignment Q
    oregon
    hey everyone
    Who here understands alignments?I sure could use your help.I recently did some trans work on my 98 GS and had the frame out.Everything went back perfect and fixed the issue.The steering was centered perfect,now its ever so slightly off to the left.I know I can bring it in straight by loosing frame bolts pry front of frame to one direction or the other and tighten and be straight.Who hear knows what direction to pry before tightning?I would rather do that than adjusting the toe.Thanks
  5. #5 Re: Alignment Q
    im willing to say you may never get it back where it was no matter how much you play with the cradle shifting it side to side. a 60 dollar alignment will fix it up nicely.
  6. #6 Re: 98 GS 4T65E fixed alignment Q
    merged threads.
  7. #7 Re: 98 GS 4T65E fixed alignment Q
    You may also be able to loosen the rack to subframe bolts and turn the wheel gently to "move" the rack a little. Then tighten the bolts back down. There's a little play in everything.
  8. #8 Re: 98 GS 4T65E fixed alignment Q
    PA
    As mentioned, this can get you close. But you still need a good alignment to make sure everything is aligned correctly. Or you will wear out your tires in no time flat.
    2001 GSE
  9. #9 Re: 98 GS 4T65E fixed alignment Q
    oregon
    So if it had a good alignment before,then i remove frame reinstall and now alignments out enough for uneven tire wear? how much variation from stock to custom specs,some range i bet,what adjustment changed in the alignment removing the frame?I could agree it could be slightly out,I agree moving the rack might move 1/16 of an inch could get the wheel straight BTW good idea to try,i think i need to pry it left to get could get the wheel straight, original question which way to try and move.Hey, appreciate all who posted thanks
  10. #10 Re: 98 GS 4T65E fixed alignment Q
    getting an alignment will be your best bet at having it perfect after you're done.
    they don't cost that much.
  11. #11 Re: 98 GS 4T65E fixed alignment Q
    oregon
    the car drives perfect . i dont think its out enough to bother if out at all,does removing frame automatically mean alignment is out of it large range of specs?,the car is a near creambuff for the year and miles,im in it less than a grand,all i do is drive it to town once in a while and hammer it and drive like stolen,i wont spend the $40 for alignment ,i will play with it ,I was hoping someone here knew the effects of moving the cradle or rack what direction for a certain result.Its off so little most folks wouldnt do anything.The tires will get smoked off of it before any edges develope
  12. #12 Re: 98 GS 4T65E fixed alignment Q
    Donating Users moddman's Avatar
    Midwest
    Quote Originally Posted by torq455 View Post
    X2 ........But you might want to line up the cradle to factory specs and work from there......There is alignment holes on the passenger side of the cradle I believe there is one in the back and one in the front.......You take a 3/4 steel round bar and slide it thru the cradle and into the frame with the cradle bolts loosen up and cradle supported. This will put you to factory caster spec....and you then tweak it from there.....1-caster(cradle).....2-camber(shock bolts)........3-toe(outer tie-rods).
    Here are some links to help you....
    h**p://www.elantragtclub.com/id554.html -DIY Alignment Instructions
    h**p://www.racerpartswholesale.com/ -Alignment Tools (Manual)
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  13. #13 Re: 98 GS 4T65E fixed alignment Q
    oregon
    VERY good info,valuable post.Thanks
    Quote Originally Posted by moddman View Post
  1. Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
    By MrPoopyButthole in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2012, 10:05 PM
  2. Alignment
    By dsh1106 in forum Brakes/Suspension/Chassis
    Last Post: 01-29-2011, 10:39 AM
  3. Alignment
    By matt5112 in forum Brakes/Suspension/Chassis
    Last Post: 11-13-2010, 03:51 AM
  4. 4t65E replacing 4t65e-hd question
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2010, 10:33 PM
  5. '01 alignment ?'s
    By riceburner in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 04:14 PM
