My GXP has 95,000 on it. I have a light clunking noise coming from the front end when I go over bumps at low speeds. I can't hear it high speeds and the front end seems solid.
So far I've replaced the front strut mounts and bearings, sway bar links, and torque strut mount (dogbone).
Tie rod ends seem tight, doubt its the ball joints? I'm thinking the next replacement would be tie rod ends, even though I don't feel/see any movement when grabbing the tire and moving it back and worth and side to side.
ANY IDEAS???
I thought for sure it was the strut mounts, but they did nothing, not a bad thing to replace though I guess.
Thanks,
Eric
