Thread: Hot brake discs
Results 1 to 11 of 11
  1. #1 Hot brake discs
    Jul 2010
    I honestly don't know if this has been put up yet or not, low on time here so posting this quick. Both of my front brake discs (or w/e there called) are hot. And this was maybe a 3 mile trip if that. Came home looked at them then touched and they were pretty damn hot. The back ones are fine they were just lightly warm which is fine. But the front ones were scorching. Then i took another little 3 miles trip 10 minutes after this and they were cooled off and fine. I don't think they were sticking, since it doesn't seem right that both would be. But any ideas would be nice.
  2. #2 Re: Hot brake discs
    Omaha, NE
    Are you talking about your rotors?
    If so upgrading to drilled/slotted rotors and ceramic pads should help keep your brakes cooler.
    Since it's only the fronts giving you problems, you may want to see if they are warped.
  3. #3 Re: Hot brake discs
    Define hot with a temperature.
    For a little example...
    Car mass is 3400 lbs, you are ~180.
    3580 lbs you need to bring from 40 mph to zero.
    All of that energy is turned into heat and stored in your rotors.
    Which have a mass of 15 lbs.
    So.... of course they're going to be hot.
    But as long as they're under 500* F you're more than okay.
    Some higher performance pads don't even get into their efficiency range until 300* F or higher.
    Also drilled and slotted wont do anything...
    You want brake rotor ducting.
    Good luck with that though.
    With the power steering rack being mounted on the back side of the spindles, GM was "forced" to mount the calipers on the leading edge of the rotors.
    Thus making brake ducting rather difficult.
    Edit: IIRC removing the dust shields will help with temps.
    But at the cost of increased brake dust in the engine bay. As agent____screen was talking about.... this can block the magnet on your CPS and thus cause it to fail earlier.
  4. #4 Re: Hot brake discs
    Jul 2010
    So your saying it is normal for them to be pretty hot? But why are the fronts so much hotter then the back ones? And this only started recently.
  5. #5 Re: Hot brake discs
    Because our weight distribution is 65/35.
    And when you brake most of the weight is transferred to the front.
    Thus requiring the front brakes to do most of the work.
    http://stoptech.com/tech_info/wp_bra...formance.shtml
  6. #6 Re: Hot brake discs
    Yes its normal for rotors to get hot or super hot.
    Thats a lot of friction going on to stop your momentum.
  7. #7 Re: Hot brake discs
    Jan 2009
    Tallahassee, FL
    What those guys said, *enter physics explanation*
    It's normal so nothing to worry about. If you think yours get hot go watch a race and see how much heat gets put out.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  8. #8 Re: Hot brake discs
    Waukesha, WI
    they get red hot
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  9. #9 Re: Hot brake discs
    utah
    ....this thread is EXACTLY what i was hoping it to be. hahahahaha. brakes iz hawt! your fronts are most of your stopping power..thus them being more hoterish then the rears. as stated before. so now i have two questions. 1: is there any pedal vibrations and or noise? 2: dont lie, how often do you touch your rotors after you drive?
  10. #10 Re: Hot brake discs
    grab your exhaust pipe next time you get of the car...:chuckle:
  11. #11 Re: Hot brake discs
    utah
    Damn that's hawt....
  1. brake parts to get for brake upgrade??
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 01-03-2011, 08:59 PM
  2. Brake discs - a good cheap set?
    By Deezul_AwT in forum Brakes/Suspension/Chassis
    Last Post: 06-18-2010, 03:20 PM
