Thread: cheap wheel bearing hubs worth it?
Results 1 to 10 of 10
  1. #1 cheap wheel bearing hubs worth it?
    SE Level Member brianwalter86's Avatar
    Apr 2011
    michigan
    I own a 04 gp gt. The left front wheel bearing is going bad. I changed my lim gasket and right after that I have this stupid abs problem. When I stop my abs kicks in when I am almost to a dead stop.
    So I decided since I have a bad wheel bearing ill fix that first and hope that fixes my problem. I am not getting any codes or lights.
    At autozone they have a duralast and a timkin for sale. The timkin is like $300 and the duralast is. Like 140
    I found the same model number timkin online at amazone.com for anout 124.plus shipping.
    Only thing is I don't know if it will have a warrenty.
    Advanced auto parts has some real cheap. There's is only $107. Its made by drive works.
    So does brand matter? Or price? Should I ask autozone to match the duralast price with the drive works?
    Some advice on brands and price would help me out a lot.
    Thanks
  2. #2 Re: cheap wheel bearing hubs worth it?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    timken only. Duralast are junk. trust me. Just look at the two and you will see a huge differance.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: cheap wheel bearing hubs worth it?
    Waukesha, WI
    check rockauto
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  4. #4 Re: cheap wheel bearing hubs worth it?
    Charles City, IA
    Timken,SKF,Precision are the ones I use.
    SMGPFC Two Nipple General
  5. #5 Re: cheap wheel bearing hubs worth it?
    Feb 2008
    Timken all the way! Don't bother with the cheap ones. Not even worth the effort of installing them.
  6. #6 Re: cheap wheel bearing hubs worth it?
    GT Level Member neel2008's Avatar
    Huntington, IN
    yea id either spend the money on timken or buy the cheapest ebay ones you can find to get you by so you can buy the timken later lol. if you find timken ones at another regular parts store, your autozone should match it just fine as well...wont match online only prices though...
    97gtp
  7. #7 Re: cheap wheel bearing hubs worth it?
    Grand Rapids, MI
    buy timkens. they can be had at rockauto.com for 90 bucks, SAME timken part and part number that autozone has for a million dollars.
  8. #8 Re: cheap wheel bearing hubs worth it?
    Apr 2011
    michigan
    Ok thanks. Very true. Rockauto.com does have. Just ordered it. Thanks guys.
  9. #9 Re: cheap wheel bearing hubs worth it?
    Apr 2011
    michigan
    $317 autozone for timkins
    $90 at rockauto.com for same part.
    Thanks for the site guys. Its unbeliveable.
  10. #10 Re: cheap wheel bearing hubs worth it?
    I have an Advance Commercial account so I'm well taken care of.. I will often use their National brand. But a wheel hub is 1/2 mile to the store or delivered and about 20 minutes most of the time. SKF and Timken are the most preferred though.
  1. Discussion on wheel hubs
    By BillBoost37 in forum Brakes/Suspension/Chassis
    Last Post: 01-04-2011, 08:55 AM
  2. How much is an 04 comp g worth with 120k and a spun bearing?
    By CandyBlueta in forum Off Topic Discussion
    Last Post: 11-18-2010, 02:21 PM
  3. New Wheel Hubs
    By Mohatmus in forum Brakes/Suspension/Chassis
    Last Post: 11-08-2009, 09:55 PM
  4. I want these rims but they wont fit, new wheel hubs?
    By Quicklynx in forum Tires & Wheels
    Last Post: 07-16-2009, 02:04 PM
  5. Wheel Bearings/Hubs
    By bcrosby51 in forum General Tech Discussion
    Last Post: 09-15-2008, 01:49 PM
