Thread: Subframe or engine cradle bolts HELP
Results 1 to 7 of 7
  1. #1 Subframe or engine cradle bolts HELP
    SE Level Member ryan12473's Avatar
    Dec 2010
    Iowa, Burlington
    I was under my car 99 gtp to install a zzp dp and my subframe bolts were so lose there was alot of space between the bushings and the car. I tried to to tighten them but the driverside just spun, this is the side I'v had trouble with starting when dealership replaced tranny. Apparently they forgot to tighten bolt and it fell out so they fixed it and all was well. Then I went to install a gmpp sway bar and the bolt broke off flush,I ended up having a body shop get it out and put a new bolt in. That takes us to now the captured nut up in the body is'nt captured anymore and it just spins. Im going to see what the bodyshop says but if they wont stand behind their work my plan of attack is to peel back the carpet and cut a hole in the floor above the nut and go from there. If anyone has any experience with this please chime in I could use some help.
  2. #2 Re: Subframe or engine cradle bolts HELP
    Charles City, IA
    Try to blip it with an impact.
    SMGPFC Two Nipple General
  3. #3 Re: Subframe or engine cradle bolts HELP
    Waukesha, WI
    if the nut is broke loose, the ONLY way is to peel back the floor and cut a hole and weld the nut back down
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  4. #4 Re: Subframe or engine cradle bolts HELP
    Dec 2010
    Iowa, Burlington
    I tried everything with my impact even all the weight off and on. No dice.
  5. #5 Re: Subframe or engine cradle bolts HELP
    Waukesha, WI
    yea your f.d. get to cutting
    RayRay
    92 Turbo miata
    02 lexus is300
  6. #6 Re: Subframe or engine cradle bolts HELP
    Dec 2010
    Iowa, Burlington
    yeah I figured as much. First I'm gonna see what the bodyshop will do,because there the ones the broke the clip that holds the nut.
  7. #7 Re: Subframe or engine cradle bolts HELP
    Or rust and time broke the clip.
  1. cradle bolts....
    By Piggy in forum General Tech Discussion
    Last Post: 08-17-2009, 02:26 PM
  2. What exactly are the cradle bolts?
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2009, 03:15 PM
  3. Cradle bolts
    By Sabrewings in forum General Tech Discussion
    Last Post: 09-12-2008, 11:49 PM
  4. Subframe Bolts
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2008, 04:04 PM
  5. Tightening cradle bolts
    By Sabrewings in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-26-2008, 11:06 PM
