Thread: Suspension Refresh
Results 1 to 2 of 2
  1. #1 Suspension Refresh
    SE Level Member montecarlo01ss's Avatar
    Michigan
    picked up some ssc's working on what strut combo i want with them but while im in there what else should i be replacing? got 130k miles, its my dd so i cant just start tearing into it and not have parts ready to go in if i need them. part numbers would be helpful
    01 Monte Carlo SS- 3" Hogan Catless DP* ZZP FWI* ZZP Mounts* Dual Magnaflows* AL103's* S&S Headers* 180 t-stat* 6000k HIDs* M90 w/3.3" *Custom PCM *XP Cam*P/P L67 TB* Custom Heads w/valve job & 105#'s
  2. #2 Re: Suspension Refresh
    new LCA's, sway bar links, sway bar bushings (or bars if yours are rotting, GMPP kit from gmpartsdirect.com is usually a good value) and possibly tie rod ends.
    Moog makes good stuff.
  1. 97-03 GTP suspension
    By GPSE in forum Brakes/Suspension/Chassis
    Last Post: 10-20-2010, 09:46 AM
  2. refresh or engine swap?
    By bstuby in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2010, 05:43 PM
  3. 150K suspension refresh
    By Smokin2000gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 08:14 PM
  4. Energy Suspension Suspension Parts
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 03-09-2009, 10:25 PM
  5. Help!! Tranny Swap Engine ''Refresh''
    By TDCRacing in forum General Tech Discussion
    Last Post: 06-10-2008, 12:04 PM
