Thread: problem with R1 concepts brakes?
Results 1 to 20 of 21
  1. #1 problem with R1 concepts brakes?
    GT Level Member Euro's Avatar
    Roselle, IL
    Hey all,
    After seeing so many raves about R1 Concepts rotors for our cars, I bought a set of 4 of their E-Line series with pads from ebay. I put the rears on yesterday, and took it for a test drive just a few minutes ago.
    Well, they have a sort of metal on metal grinding noise when driving, and then the pads make noise when the brakes are applied. I'm 95% sure I didn't mess anything up when putting them on, I've done brakes on GP's at least a dozen times. Another thing, is that the pads are dusting all over the ****in place on the rotor. I'd say half of the pad surface on the rotor has brake dust on it. Anybody have any suggestions?
    Do I have to break them in a certain way? I was trying to break them in on the test drive doing gradual stops from different speeds, do I have to just let them settle in some? Thanks all!
    2000 Regal GS - 190k - Black over Storm Gray Metallic - 9" K&N/AL104's/Borla/GP polished tq stars/turd
    2009 Impala LT - 62k - Car Seat Mobile
    2000 Grand Prix GT - 96k - Sold/RIP
  2. #2 Re: problem with R1 concepts brakes?
    SE Level Member black.gtp's Avatar
    Apr 2008
    Indiana
    I had a similar problem but my front calipers were shot had to replace them they wouldn't release All is fine now
    PRJ Built enough said!!!!
    www.prjperformance.com
  3. #3 Re: problem with R1 concepts brakes?
    Roselle, IL
    That had crossed my mind on the drive, but I didn't think that they would both go bad at the same time. They were fine with my old brakes. That better not be the case, I just freaking painted the calipers!
  4. #4 Re: problem with R1 concepts brakes?
    Apr 2008
    Indiana
    well I wasn't sure which one was bad as the drivers side really didn't seem to work all that well and I thought the pass side was sticking so @ $25 a side I got both
  5. #5 Re: problem with R1 concepts brakes?
    St. Louis Mo.
    What kind of pads are you using? It sounds like the pads are tearing up. I know with the slotted and drilled R1s I have, they dusted up a bit in the beginning, but once the pads settled, the brake dust has been nonexistant.
    I am using Posi Quiet ceramic brakes pads with my R1 Rotors.
    I have to say I highly doubt it would be the rotors being bad. Do you feel the brakes pulsate or anything when you apply them? Indicating a warped rotor or anything? I would check your pads and see what kind of condition they are in. And are they new pads or ones you had from your prior setup?
    James Shafer
    St. Louis MO
  6. #6 Re: problem with R1 concepts brakes?
    Apr 2008
    Indiana
    Quote Originally Posted by Euro View Post
    he has new pads from R1 check the calipers to make sure they are releasing take the tire off have someone hit the pedal then see if the calipers moves after the pedal is released
  7. #7 Re: problem with R1 concepts brakes?
    Roselle, IL
    Well, my dad drove it earlier tonight and said it wasn't making as much noise like I heard. He did say the pads are leaving a noticeable amount of brake dust. I think I'll just drive it for a few days and see if it gets any better. Thanks all!
    Edit : I'm not certain that my calipers are stuck up, because I hear the pads coming in contact with the rotors when I press the brakes, and letting off when I release. But....I'll observe over this week and see in a few days
  8. #8 Re: problem with R1 concepts brakes?
    GTX Level Member webracin's Avatar
    Arkansas
    I can tell you that if you are using semi metalic pads, they will leave ALOT more dust than the ceramic pads. I would bet you have the semi metalic which will also make make some noise with these rotors.
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  9. #9 Re: problem with R1 concepts brakes?
    St. Louis Mo.
    Quote Originally Posted by webracin View Post
    webracin
    ^^^^^^ What he said.
    If they are metallic, they are gonna be a bit more nosiey than ceramic, not by much but enough to notice. And the dusting is night and day compared between the two.
    I am glad to hear the noise has lessened. It might just be the pads trying to "bed" against the new rotors. Metallic pads are gonna be more crunchy the first time or two out. If they are metallic truly, you are always gonna have that dusted look on your rims till you switch over to Ceramics.
    James Shafer
    St. Louis MO
  10. #10 Re: problem with R1 concepts brakes?
    Roselle, IL
    Yeah, they're definitely quieted down today. It's just they dust like an SOB though!!!!!!! The pads I got were whatever pads that came with the rotors. So, I think I'm going to buy a better set of ceramic pads before I do the fronts over the weekend. Thanks for all your input guys!
  11. #11 Re: problem with R1 concepts brakes?
    St. Louis Mo.
    Here is a link to the ones I and Sab are running. They are Posi Quiet full ceramic pads. And I can not say enough good things about them. And their price is ubar cheap!
    http://cgi.ebay.com/ebaymotors/Grand...spagenameZWD1V
    eBay Motors: Grand Prix 97-03 Rear Set Posi Quiet Ceramic Brake Pads (item 160250937625 end time Jul-13-08 17:42:38 PDT)
    James Shafer
    St. Louis MO
  12. #12 Re: problem with R1 concepts brakes?
    Barksdale AFB, LA
    Actually, I've got the Posi Quiet semi-mets.
    2009 Subaru Impreza WRX STI
  13. #13 Re: problem with R1 concepts brakes?
    St. Louis Mo.
    Quote Originally Posted by Sabrewings View Post
    James Shafer
    St. Louis MO
  14. #14 Re: problem with R1 concepts brakes?
    Roselle, IL
    yeah they're definitely clicking. Pretty funny when I hit the brakes and it sounds like 4 million people are snapping their fingers.
  15. #15 Re: problem with R1 concepts brakes?
    St. Louis Mo.
    Hummmm ok dumb question, but I know with mine, when I ride on the highway and I am up against the barrier wall I can hear the air in the drilled holes. Not sure if sounds like clicking, but I dont hear when I am out in the open but when I am up along side another car or a barrier wall or something I can hear that.
    The only other thing I can think of would be tearing them completely down and then rechecking all bushings and clips that hold in the pads. And then regrease the edges of the pads that rest in the clips and regrease the pins as well that go into the calipers. Also check to make sure your rims arent possibly rubbing against the caliper, that is if you got the 12" brake upgrade and still have your stock 16" rims.
    That's the best I can come up with. Sorry to hear you are having such a time with them.
    James Shafer
    St. Louis MO
  16. #16 Re: problem with R1 concepts brakes?
    Roselle, IL
    Thanks! I actually haven't done the fronts yet...this is all for the rears lol! the clicking noise is only when I put on the brakes, and I can only hear it when I'm driving through a neighborhood or by a shoulder barrier on the side of the road like you said. It doesn't bother me much, I have no loss of braking power or anything kind of performance issue.
  17. #17 Re: problem with R1 concepts brakes?
    GT Level Member adidasdude1061's Avatar
    Jul 2008
    P-Town, MN
    Well at least yours don't squeak and grind. haha I am having hella trouble with my car and I just got it 2 weeks ago. Going to get some quick struts to see if that will fix the ungodly clunking in the rear, and who knows what the hell I am going to do with the breaks.
    '97 BLACK GTP--Chrome K&N CAI--3.5" MPS--3" RT Cat Downpipe--180*Tstat--Tuned PCM--Alpine 9886--Kicker Amp - 2 12" Kicker L7's--ALT boost&rewire
  18. #18 Re: problem with R1 concepts brakes?
    St. Louis Mo.
    Quote Originally Posted by adidasdude1061 View Post
    What are your brakes doing? Which Rotors did you wind up getting? And what pads are you using on them?
    James Shafer
    St. Louis MO
  19. #19 Re: problem with R1 concepts brakes?
    Jul 2008
    P-Town, MN
    E Line Rotors (Diamond Slotted and Drilled) and semi Metallic pads, and whenever I am light on the brakes, they squeak like no other. I believe its only the fronts, because I put the rears on and had them on a day before the fronts, and there was no squeaking. Maybe they just need broken in? IDK
  20. #20 Re: problem with R1 concepts brakes?
    St. Louis Mo.
    Well I can not comment on the metallic pads, I have ceramic myself, but I know my R1's are not making any noise like that. Its hard to say, but I would lay money on the pads more than anything else being your problem.
    James Shafer
    St. Louis MO
  1. longer SS brake lines (fbody brakes)
    By UR LOSN in forum Brakes/Suspension/Chassis
    Last Post: 03-30-2008, 02:38 PM
  2. Stupid brakes are spungy
    By 8sec-z in forum Brakes/Suspension/Chassis
    Last Post: 01-10-2008, 10:13 AM
  3. Powdercoating brakes/mounts [*]
    By kyle99gtp in forum How To Write-Ups/Tech Tips
    Last Post: 12-17-2007, 03:41 PM
