Thread: Wet weather braking issue
Results 1 to 10 of 10
  1. #1 Wet weather braking issue
    Jerseyville, IL
    Hi all, long time lurker, first time poster.
    I have a 97 GP with the 04-up 12" brake conversion. I am experiencing the (apparently common) wet weather braking problem. I have to lean into the pedal for a few seconds at highway speeds before the rotors dry off enough to let the pads bite. I have been searching here and all over the internet trying to find a solution to this.
    Is there a fix? My car has the flat 5 spoke wheels, btw. I am planning to give this car to my son when he turns 16, but want this problem fixed first.
    Thanks.
  2. #2 Re: Wet weather braking issue
    GTX Level Member cerick08GP's Avatar
    Yup, there is a fix for that, slotted rotors. This site bashes all day long on ppl spending a couple extra bucks on them, but the truth is they’re worth it. In fact my #1 reason for running slotted rotors was to fix the exact issue you have noticed. Both my GPs had a little issue with wet weather braking, and I had an Accord that was horrible. Nothing quite like the feeling of stomping on the brakes, and then have them actually start working 2 seconds later. Gives me a rush!!
    Anyway, like I said slotted rotors are the only fix I know of. Just be warned there are “cheap” rotors out there, generally speaking you get what you pay for with rotors. I’m running Power Slot rotors, they are a high quality product FWIW.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: Wet weather braking issue
    why would slotted rotors make this any different besides that they have a slightly better 'bite' on the pad due to the slots? the rotor itself would still be glazed over.
    to me it sounds like your calipers are sticking a little and/or your pads are heavily worn. normally your pads graze over the surface of the rotor at a resting position so they should always be hot and ready to work.
  4. #4 Re: Wet weather braking issue
    Jerseyville, IL
    I switched from ceramic pads to semi-metallic and it helped slightly. The pads and rotors are only a couple thousand miles old, so that isn't an issue. I was thinking that new calipers might help (pistons could be sticking a bit), but don't want to waste money. I have heard lots of naysayers putting down slotted/drilled rotors, but cerick08GP is actually running them and says they work. Pontiac used drilled rotors on the GXP, so they must have some faith in them.
    Could excessive pad clearance, as in a sticking piston, cause this? I have replaced and cleaned and greased all of the hardware, pins, etc., but the calipers are original. Guess I'll rebuild those next.
  5. #5 Re: Wet weather braking issue
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    if he says it has made an improvement then im gonna give it a try but with drilled not slotted cuz they look ugly lol. but alot of people have this problem like i do and my pads are not heavily woarn and the caliper piston moves just fine. so im doing the 12'' upgrade and gonna put some drilled rotors on them n see how it works.
  6. #6 Re: Wet weather braking issue
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    The slots on a slotted rotor among other things, allows water to wash of the rotors quicker, ie via the slots which improves brake performance in wet conditions.
  7. #7 Re: Wet weather braking issue
    but if the pads are not glazed over to begin with why would it be a problem with the rotor being mildly wet? it'll burn through it immediately when they come in contact with the rotor.
    however, i've always been a big fan of semi-metallic pads because they just stop better. so what that they aren't as quiet and that they dust like crazy, they stop the car like they are supposed to. i've never been able to grasp why people would want ceramic pads unless they plan to run them for 100k miles and never touch the car.
  8. #8 Re: Wet weather braking issue
    Apr 2011
    Palm Coast, Florida
    agreed
    ceramic pads - long life, little brake dust but hard on rotors and sometimes emit noise.
    semi-metallic pads - medium life, lots of brake dust, soft on rotors and certain types very quiet.
    carbon metallic or premium semi-metallic pads - better than medium life, less brake dust than regular semi-metallic, soft on rotors, certain types very quiet.
  9. #9 Re: Wet weather braking issue
    I had cheap pads... you had to stand on it to get anything happening.
    Bought EBC reds, magic.... the brakes require very little effort now.
  10. #10 Re: Wet weather braking issue
    I had this problem with the corvette brakes too, I just hated it sometimes.
    But now I don't have the problem for other reasons....
  1. lights dim when braking
    By hourang in forum General Tech Discussion
    Last Post: 01-05-2010, 01:51 PM
  2. odd braking issue, maybe ABS?
    By Pittman06 in forum General Tech Discussion
    Last Post: 11-05-2009, 02:52 PM
  3. Odd issue... Pop/Clunking sound shifting into 2nd OR braking hard...
    By Iron Indian in forum General Tech Discussion
    Last Post: 07-09-2009, 10:28 PM
  4. Weather Stripping Issue
    By Nickell in forum Visual/Body Modifications
    Last Post: 01-06-2009, 11:05 PM
  5. braking problem
    By beastin1 in forum Brakes/Suspension/Chassis
    Last Post: 12-11-2008, 09:25 AM
