Thread: Rattling going over bumps. And while braking. SOLVED
Results 1 to 19 of 19
  1. #1 Rattling going over bumps. And while braking. SOLVED
    SE Level Member speedy2's Avatar
    NW Florida
    I cannot figure this out. I haven't had a chance to get the car off the ground yet though. It's a 2005 Comp G.
    My driveway is kinda bumpy. Idle speed. And it sounds like someone is in my trunk banging stuff. It also happens when I brake. Mostly because the rotors are a little warped. But, the vibration from that causes this rattle to happen too.
    Today I grabbed the wheel and then the spring and shook the car side to side. The sound happens too. I can't figure out where it's coming from.
    It started a few months ago, and has slowly become louder and a lot easier to reproduce.
  2. #2 Re: Rattling going over bumps. And while braking. ANNOYING!!
    Omaha, NE
    Sounds like your struts are loose or bad.
  3. #3 Re: Rattling going over bumps. And while braking. ANNOYING!!
    NW Florida
    How can I confirm that?
  4. #4 Re: Rattling going over bumps. And while braking. ANNOYING!!
    there should be no play in the struts, if so you found it already, could be the mounts at the top, pop the hood start the car and crank the steering wheel back and fourth, if there is a lot of movement where the struts bolt in thats it.
    to change the strut mounts you need to take them apart, spring compressor and all that good sh!t, no fun, i bought new mounts for my car, took out the struts and had a shop change them for me, 30 bucks and 30 minutes and i was on my way. its a 5 bolt job per side, real easy to remove.
  5. #5 Re: Rattling going over bumps. And while braking. ANNOYING!!
    NW Florida
    This is in the rear. But, I assume the process would be the same. Thanks for the info.
  6. #6 Re: Rattling going over bumps. And while braking. ANNOYING!!
    same idea minus the turning the steering wheel lol still a 5 bolt job tho. they might have just come lose, try to tighten them up first.
    the fronts are usually the ones to go, they take the most abuse.
  7. #7 Re: Rattling going over bumps. And while braking. ANNOYING!!
    NW Florida
    Will do. I gotta do something. It's driving me insane lol.
  8. #8 Re: Rattling going over bumps. And while braking. ANNOYING!!
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    yea mine does the same thing. worse when its cold tho. ill fix it sometime
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  9. #9 Re: Rattling going over bumps. And while braking. ANNOYING!!
    GT Level Member ljmonnin12's Avatar
    Nov 2010
    Sidney, OH
    just buy some good quick struts and do it yourself!
    -ljmonnin12
  10. #10 Re: Rattling going over bumps. And while braking. ANNOYING!!
    Dec 2008
    Lawndale, CA
    It's the rear strut mounts. Mine are doing it. I will be replacing them soon.
  11. #11 Re: Rattling going over bumps. And while braking. ANNOYING!!
    Feb 2010
    indianapolis
    Quote Originally Posted by ljmonnin12 View Post
    why when you can buy struts and put your springs on them for alot cheaper. get a spring compressor
  12. #12 Re: Rattling going over bumps. And while braking. ANNOYING!!
    NW Florida
    Yeah. no way I'm spending the cash on a complete strut/spring/mount.
    Anyone know the best place to get the mounts?
  13. #13 Re: Rattling going over bumps. And while braking. ANNOYING!!
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    amazon has the quick struts for $112. and free shipping. And Monroe has a rebate going on where you buy 3 struts, you get the fourth free.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  14. #14 Re: Rattling going over bumps. And while braking. ANNOYING!!
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    I have this noise as well. Extremely annoying.
  15. #15 Re: Rattling going over bumps. And while braking. ANNOYING!!
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by speedy2 View Post
    rock auto has the monroes for a good price. Don't forget the rock auto discount code.
  16. #16 Re: Rattling going over bumps. And while braking. ANNOYING!!
    NW Florida
    Quote Originally Posted by The Guz View Post
    Code? What code?
  17. #17 Re: Rattling going over bumps. And while braking. ANNOYING!!
    Dec 2008
    Lawndale, CA
    Code? What code?
    I usually just google rock auto discount code. But you can also check the sticky over on the other topics section on club gp.
    This is the latest code
    50483143504517
    May 8, 2011
    Using Your Discount Code
    Enter the code above in the "How did you hear about us" line of the shopping cart. If you are using our traditional HTML catalog, please click the "Apply" button to the right of the field. Your discount will automatically appear, subtracted from your order total.
    Please note: We sometimes get calls from people who put the word "discount" in front of their code and do not get the discount. Please enter ONLY the discount code, no other words or numbers.
    The discount takes 5% off our already-low prices. There's no limit on order size or the number of orders. Use the code for your next order, and share the code with friends, neighbors, relatives, the guy at the corner garage--anyone you know who works on cars or trucks.
  18. #18 Re: Rattling going over bumps. And while braking. ANNOYING!!
    NW Florida
    Update!!!
    Turns out it was the trailing arm. The bolt had come loose. Apparently very loose. It was almost out. I took it too a guy in town. He did it no charged. Went to school with his son. Now, the car is in tip top shape. yay!
  19. #19 Re: Rattling going over bumps. And while braking. SOLVED
    Dec 2008
    Lawndale, CA
    Good to hear that you got this issue resolved. I'll have to check mine out.
  1. chime when I hit bumps
    By Carbon Summit in forum General Tech Discussion
    Last Post: 12-27-2010, 08:25 PM
  2. Clunking noise over bumps
    By Amb4 in forum Brakes/Suspension/Chassis
    Last Post: 08-04-2010, 08:26 PM
  3. in need of some bumps
    By 02gtp40 in forum Audio, Security & Visual Electronics
    Last Post: 06-20-2010, 08:31 PM
  4. Rattling felt (and heard) in steering when turning and going over bumps
    By michgym170 in forum Brakes/Suspension/Chassis
    Last Post: 10-07-2009, 10:41 AM
  5. Squeak when going over Big/Speed Bumps
    By ravi in forum Brakes/Suspension/Chassis
    Last Post: 08-19-2009, 02:01 PM
