Thread: DNA springs... yep i said it
Page 11 of 22 FirstFirst ... 91011121321 ... LastLast
Results 201 to 220 of 435
  1. #201 Re: DNA springs... yep i said it
    Keep this thread clean.
    Don't like it?
    Don't post.
    Don't need negative crap in here.
    If this thread gets closed, then sorry OP...you can blame the members who like to spew junk from their mouth.
    Thanks.
  2. #202 Re: DNA springs... yep i said it
    Oct 2011
    Puyallup WA
    Yes sir! Only reason I bumped this thread was to provide more info for people that are interested in them...If anyone else wants info about these PM me!
    08 G8 GT - exhaust Tune
  3. #203 Re: DNA springs... yep i said it
    What are the spring rates?
  4. #204 Re: DNA springs... yep i said it
    Oct 2011
    Puyallup WA
    450 Front 250 Rear
  5. #205 Re: DNA springs... yep i said it
    michigan
    Not everyone can afford the best of the best top of the line expensive parts that some may be able to, so ppl try and find a cheaper alternative. We all value each others opinion to a degree. I agree to an extent both sides, yes they may not be the best quality....but obviously ppl are trying them with good results..for now. Let's give it awhile and see what happens, might be ok might not be. But these ppl are brave enough to be guinea pigs so to speak. Im interested as well to see how these pan out. If they fail, we know not to use them, if not, we found another cheaper route to use. And im sure all of us would love to save some extra cash on this expensive hobby! Lol
  6. #206 Re: DNA springs... yep i said it
    Quote Originally Posted by wa04compg View Post
    450 Front 250 Rear
    If they are, you must be bouncing all over the place.
    What is the open height and height at ride level.
  7. #207 Re: DNA springs... yep i said it
    Oct 2011
    Puyallup WA
    No they are not bouncy...they ride similar to stock but a bit stiffer...springs rate is what was on the add...any other info I don't know other then how they ride
  8. #208 Re: DNA springs... yep i said it
    Then they're probably closer to 200/140 or less.
  9. #209 Re: DNA springs... yep i said it
    Oct 2011
    Puyallup WA
    Yeah I agree with you on that one...I don't know what the stock spring rates but these are similar in ride quality just a touch stiffer...stock my suspension was already pretty stiff though...I do know that I had to compress them a decent amount to get the tophats on
  10. #210 Re: DNA springs... yep i said it
    Didn't you have trouble with agx's? Which are supposedly the best strut for lowering?
    Lol......
    Yes I did with eibach springs and guess what they were used and came off vinnies white coupe. When I had my AGX's on my regal I talked to others that had clunks noises from them aswell yet again how many people have negative reviews about these? Besides the Ohh they are too cheap and CANNOT be worth the 80 bucks hell if they ride fine and last a while one could buy at least 3 sets for the cost of what others are new.
  11. #211 Re: DNA springs... yep i said it
    Donating User Odi's Avatar
    Chicago South Suburbs
    lolololol stock suspension was pretty stiff. you havent seen a stiff spring if you say dna's are stiff.
    and vet, my used agx work fine.
  12. #212 Re: DNA springs... yep i said it
    I still wanna believe one in the rear had a blown strut I swear to god I checked them mounts over and over and they were in perfect shape when I put them in. Cant visually inspect a blown strut
  13. #213 Re: DNA springs... yep i said it
    Oct 2011
    Puyallup WA
    Yes my Comp G suspension was pretty firm stock yes the DNA springs are stiffer then the stocks yes I have had alot stiffer suspension setups on my subaru yes I know what a stiff spring rides like...
  14. #214 Re: DNA springs... yep i said it
    GTP Level Member buickman104's Avatar
    NYC
    I'll be installing my DNA springs this Sunday. I can't wait.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  15. #215 Re: DNA springs... yep i said it
    am i supposed to be impressed now?
  16. #216 Re: DNA springs... yep i said it
    Oct 2011
    Puyallup WA
    Nope because I have no clue what Im talking about
  17. #217 Re: DNA springs... yep i said it
    Jun 2011
    Detroit, MI
    I'm looking into these springs, for this summer. It would make my suspension a hell of a lot cheaper to replace.
    iLoveSpade
  18. #218 Re: DNA springs... yep i said it
    Until someone has a set that have failed I say do it!
  19. #219 Re: DNA springs... yep i said it
    i could see these being a useful option if youre just dropping on stock struts. if you're doing a rebuild with something more performance oriented i would definitely sway to something more proven with spring rates that are better suited for the application.
  20. #220 Re: DNA springs... yep i said it
    Oct 2011
    Puyallup WA
    I agree...on my stock comp g struts they work fine...if u want something really stiff get struts you can adjust and a spring to compliment them
  1. 97-03 springs vs 04+ springs
    By dsh1106 in forum Brakes/Suspension/Chassis
    Last Post: 10-11-2011, 03:25 PM
  2. DNA Springs?
    By Odi in forum Brakes/Suspension/Chassis
    Last Post: 06-17-2010, 04:12 AM
  3. Which springs to get
    By robahr24 in forum General Tech Discussion
    Last Post: 07-23-2009, 08:41 AM
