Thread: DNA springs... yep i said it
Page 22 of 22 FirstFirst ... 12202122
Results 421 to 435 of 435
  1. #421 Re: DNA springs... yep i said it
    Oct 2011
    Toledo, OH
    Reviving this DNA thread for a question someone might know.
    Which way is up on the front springs?
    7"
  2. #422 Re: DNA springs... yep i said it
    Skinnier part
    04 Comp G.
  3. #423 Re: DNA springs... yep i said it
    Oct 2011
    Toledo, OH
    Skinnier part
    The fronts have all the same diameter coils. Or do you mean the side that has one coil slightly closer to the rest is the side that goes up?
    7"
  4. #424 Re: DNA springs... yep i said it
    Oct 2011
    Toledo, OH
    Never mind. Figured it out. For future reference for anyone: Notice the rear springs only go on in one direction, well there is a notch at the bottom. The front springs have the same notch, indicating the bottom.
    7"
  5. #425 Re: DNA springs... yep i said it
    Oct 2014
    I installed the DNA springs on my car last night and the rear is too high, raised an inch. I was sitting at 28 all around stock, now its 27 in the front and 29 in the rear. I'm thinking of cutting off a coil from the rear spring. Anyone who has done this please let me know if you have had any issues. It rides pretty good just not crazy about the dukes of hazard rake.
  6. #426 Re: DNA springs... yep i said it
    Dec 2010
    DMV
    Typical issue on dna Springs. They are cheap for a reason. Save a little more monies and get Ssc Springs. I think member here cut his dna Springs. Maybe he will chime in
  7. #427 Re: DNA springs... yep i said it
    Nov 2012
    Madison
    Dsmuts
  8. #428 Re: DNA springs... yep i said it
    Buffalo
    I ended up using ssc fronts and kept the DNA rear end for the rake. I also have SSC rears from an intrigue that is supposed to raise the rear as well , but these seem to do the job so far.
    Some don't like rake. And to be honest , it's usually always the rears that are lower then the front with cheap springs. Go figure
  9. #429 Re: DNA springs... yep i said it
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    No one realizes the rear springs have sagged over time until they put a lowering spring on it and it sits the same or higher in the rear than it did with the saggy original springs on it...lol Pretty common scenario on these cars!
  10. #430 Re: DNA springs... yep i said it
    I didn't use dna springs. I thought they were but they are a different brand
  11. #431 Re: DNA springs... yep i said it
    Oct 2011
    Toledo, OH
    My rears have settle a little since July at less than 2000 miles.
    7"
  12. #432 Re: DNA springs... yep i said it
    Nov 2012
    Madison
    Didn't you cut a 1/4 coil in the rear?
  13. #433 Re: DNA springs... yep i said it
    Yeah I did.
  14. #434 Re: DNA springs... yep i said it
    Oct 2014
    How much did a quarter coil drop you? Did the stiffness change much?
  15. #435 Re: DNA springs... yep i said it
    Nov 2012
    Madison
  1. 97-03 springs vs 04+ springs
    By dsh1106 in forum Brakes/Suspension/Chassis
    Last Post: 10-11-2011, 03:25 PM
  2. DNA Springs?
    By Odi in forum Brakes/Suspension/Chassis
    Last Post: 06-17-2010, 04:12 AM
  3. Which springs to get
    By robahr24 in forum General Tech Discussion
    Last Post: 07-23-2009, 08:41 AM
