Thread: ABS, TCS problems?
Results 1 to 6 of 6
  1. #1 ABS, TCS problems?
    SE Level Member astros2900's Avatar
    detroit
    Recently my abs and TCS off lights have come on. They will disappear once and awhile but are usually on. Also the wheel is much harder to turn when the ABS light is on. Any Ideas?
  2. #2 Re: ABS, TCS problems?
    Omaha, NE
    Sounds like a wheel hub bearing.
  3. #3 Re: ABS, TCS problems?
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    Not sure why the wheel would be harder to turn.
    Get under the car and inspect the ABS wires to see if any are worn and exposing the wire, that will short out the system and disable the ABS. If all the wires look good you might have to have the stealership tell you which sensor is bad.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  4. #4 Re: ABS, TCS problems?
    GT Level Member ljmonnin12's Avatar
    Nov 2010
    Sidney, OH
    My lights are on and at first I noticed it was harder to turn. But I'm used to it now so I don't even realize it. It's the hub. I'm ordering a new one here soon.
    -ljmonnin12
  5. #5 Re: ABS, TCS problems?
    detroit
    Any idea how to tell which hub it is without jacking it up?
  6. #6 Re: ABS, TCS problems?
    Nov 2010
    Sidney, OH
    Not without jacking it up. Just jack it up and check which wheels have some play in them.
    -ljmonnin12
  1. you think you got problems
    By avelate63 in forum The Rant Forum
    Last Post: 07-30-2010, 01:58 AM
  2. MAF problems (i think) HELP!
    By Nig Gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2010, 06:31 PM
  3. A few problems with my GTP
    By Girevik in forum General Tech Discussion
    Last Post: 02-10-2010, 02:08 PM
  4. Problems with 98 GTP?
    By splinter in forum General Tech Discussion
    Last Post: 01-14-2010, 06:00 PM
  5. 2 problems need help with
    By kenneth74gt in forum General Tech Discussion
    Last Post: 04-19-2009, 02:21 AM
