I just got new tires on my '05 CompG and wanted an alignment but the tech said he needed to slot my struts which would cost $50 a pop. He said I could do it myself and that I needed to slot the bottom hole and that usually they have a mark that outlines how far to slot them. He also said that camber bolts would not get me enough adjustment (apparently they are way out of spec).
I really hate to take a die grinder to my struts before confirming what I need to do. Can somedody tell me how much to slot the holes and if it is in fact the bottom hole that needs to be elongated? Somebody told me that you need to slot the top hole on the front struts and the bottom on the rear, is that correct?
I greatly appriciate any help.
Thanks, Casey
05 CompG, ZZP PCM, 104s, 180 stat, drop in K&N, drilled rotors
