Thread: Dorman vs. GMPP swaybar?
Results 1 to 18 of 18
  1. #1 Dorman vs. GMPP swaybar?
    Feb 2008
    Any opinions?? I'm either getting the GMPP kit of gmpartsdirect or the GMPP rear and the Dorman front. I've heard that both the GMPP front and the Dorman front are the same diameter, but the Dorman one is solid all the way through. I honestly don't think I'd really notice a difference on my DD, but I just wanted to know everybody's opinions.
    thanks!
  2. #2 Re: Dorman vs. GMPP swaybar?
    GT Level Member ill12will8's Avatar
    DC/MD
    i ordered the dorman from rockauto. i will install it tomorrow but im already impressed by the construction
    1997 Artic White GTP: Stock (I call her "Brooke")
    2000 Silvermist GTP: ZZP DP, CAI w/ 9" open cone, Dorman front sway bar, PEMs, AL605 -DEAD & GONE
  3. #3 Re: Dorman vs. GMPP swaybar?
    Feb 2008
    Could you snap a couple of pics of the ends of the bar before the install? I hear it is built quite nicely.
  4. #4 Re: Dorman vs. GMPP swaybar?
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    subscribed bcuz i would like to see this info also
  5. #5 Re: Dorman vs. GMPP swaybar?
    Waterloo, Iowa
    but form what ive read and hurd the dorman one is a improvment bcuz it is more solid and more stable so jsut save some money and get the dorman one
  6. #6 Re: Dorman vs. GMPP swaybar?
    Donating User Odi's Avatar
    Chicago South Suburbs
    unless u plan on autocrossing GMPP kit is enough. i would opt for a solid bar tho.
  7. #7 Re: Dorman vs. GMPP swaybar?
    Charles City, IA
    Dorman is solid, and the ends are thicker and not stamped. I put lots of them in at work.
    SMGPFC Two Nipple General
  8. #8 Re: Dorman vs. GMPP swaybar?
    DC/MD
    Dorman on bottom
    Broken end
  9. #9 Re: Dorman vs. GMPP swaybar?
    Feb 2008
    That looks pretty nice. It's slightly bigger than stock but it looks like much better build quality
  10. #10 Re: Dorman vs. GMPP swaybar?
    DC/MD
    alot better quality and was a breeze to install. removing the old links was the problem
  11. #11 Re: Dorman vs. GMPP swaybar?
    13mm ratching wrench or air ratchet makes a FSB swap like into a 5 minute job...seriously.
  12. #12 Re: Dorman vs. GMPP swaybar?
    St. Louis
    Quote Originally Posted by Mjcanton View Post
    Not only is it bigger, but solid as well...
    Stock Front - 28mm - Hollow
    Dorman Front - 34mm Solid
  13. #13 Re: Dorman vs. GMPP swaybar?
    Donating Users joshuaandrew92's Avatar
    Jul 2010
    Bluffton, IN
    the gmpp bar i bought from jegs was 34mm solid looks exactly like that dorman bar
  14. #14 Re: Dorman vs. GMPP swaybar?
    St. Louis
    How much was the GMPP bar from Jegs? I've seen the Dorman bar on Ebay go for $75, including new endlinks and all bushings needed to fit said bar.
    I just scored one like this for $76.54 shipped Should play well with the GMPP rear bar and tubular rear arms that I got from Geddy.
  15. #15 Re: Dorman vs. GMPP swaybar?
    rear GMPP bar left me wanting.
    Definately made a difference in my steering feel however.
  16. #16 Re: Dorman vs. GMPP swaybar?
    St. Louis
    I've heard that too, but for the price I couldn't pass it up. Plus this being my DD I really don't need the most expensive bar out there. I promised myself that I would just replace stock for stock, but it seems I have given up on that, lol... I figure if its broke then why not upgrade
  17. #17 Re: Dorman vs. GMPP swaybar?
    Joliet, IL
    going dorman front gmpp rear over here
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  18. #18 Re: Dorman vs. GMPP swaybar?
    North Jersey
    i just put a GMPP one on my car last night not knowing about the Dorman, seems good so far, but i definitely would've went with the Dorman if i'd known before hand :-/
  1. dorman intake/stovepipe replacement
    By Pepino in forum General Tech Discussion
    Last Post: 06-15-2010, 07:28 PM
  2. Dorman Intake question
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-12-2010, 10:20 AM
  3. Dorman Intake
    By GMFI in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-28-2009, 01:11 AM
  4. Swaybar Brackets...
    By Odi in forum Brakes/Suspension/Chassis
    Last Post: 11-13-2009, 01:07 PM
