Thread: Rusting rear strut towers
Results 1 to 20 of 24
  1. #1 Rusting rear strut towers
    Jun 2010
    Stanwood, MI
    I've got a 00 Grand Prix GT. Went to replace the rear struts (Monroe Quick Struts) and noticed the the top of the tower inside the truck is rusting BAD. Is this work fixing?
  2. #2 Re: Rusting rear strut towers
    SE Level Member 99blkgtp's Avatar
    Jun 2010
    Avon,IN
    these cars are known for it. the only permanent fix is to cut that section out and weld in a new peice. as long as its not completely rusted through it should be fine
    99 Gtp - L32, xp, ported heads 130#s, 2.5" IC, n*, ported gen3, SD headers, 3" exhaust, FWI, 160* stat, 103s, 2.8, E85, PRJ tune......Sold
    04 Comp G - Slammed on Bilstein Coilovers, few little mods here and there
  3. #3 Re: Rusting rear strut towers
    Yoga city
    I doNt has a shop near me and on the outer side it has rusted through about a half inch gap that's 3 inches long will this cause my strut to shoot throughout he trunk? I'm Plannin on sanding and removing rust today but I can't take my Daliy driver off the road what are my temp solutions?
  4. #4 Re: Rusting rear strut towers
    Donating Users onetyme77's Avatar
    texas
    well i'll be a monkeys uncle!! i was jus about to post a new thread on this exact subject!!! i have the same question, mine is jus showing servre rust on the inside of the trunk and a crack underneath the wheel well. i went to a body shop and he said he cant do nothing, so he refered me to a welder,and he said he cant fix it! my next option was to buy another gp and do an engine swap, any advice would help tons
  5. #5 Re: Rusting rear strut towers
    PA
    Quote Originally Posted by onetyme77 View Post
    Find a different guy. There are plenty of places out there that can fix this. Just the places you went didn't want to.
    I think there was a youtube video somewhere of a guy fixing this on a GP
    2001 GSE
  6. #6 Re: Rusting rear strut towers
    PA
    2001 GSE
  7. #7 Re: Rusting rear strut towers
    texas
    thanks for the video, but jus like he said in the comments, most shops wont even do it (jus like the two shops i went to) plus no telling how much they will charge u if they do! if have any idea of some prices let me know, so i will know wat to expect and if i jus need to find me another gp body
  8. #8 Re: Rusting rear strut towers
    Yoga city
    I'm. Urgently looking for a welder to do
    Mine, outside of my strut is rustted through and isn't going around the strut so I don't think failure of it is in my near future so I'm
    Just gonna try and get all the rust to stop with pour 15
  9. #9 Re: Rusting rear strut towers
    texas
    i did find a body shop that said it could be fixed, and said it would cost $500. not sure if that high or reaonable, but i can only imagine how many hours of labor it would take to do both sides
  10. #10 Re: Rusting rear strut towers
    PA
    Sounds reasonable to me with the amount of work involved.
    Typically, I figure 50% of a repair bill is parts. 50% is labor. Sometimes depending on the repair it can be more or less one way or another. But in this case, $250 for labor @ $60/hr is only 4 hours. So I think that is a good price.
    2001 GSE
  11. #11 Re: Rusting rear strut towers
    texas
    I agree with the labor part. But the only parts involved is a peiece of sheet metal. I'm going to see if I can find out how long this job may take. based off of ur $60 hour rate I still think ur right about the price
  12. #12 Re: Rusting rear strut towers
    Yoga city
    My solution is just but a welder and do it myself I only need a
    1 inch by 4 inch piece of metal not bad
  13. #13 Re: Rusting rear strut towers
    PA
    It's more than just a piece of metal. The material rate usually covers stuff like grinding wheels, cutting wheels, primer, paint, weld wire, and other consumables as well. Not just a sheet of metal.
    2001 GSE
  14. #14 Re: Rusting rear strut towers
    And possibly some paint to prevent future rust.
  15. #15 Re: Rusting rear strut towers
    And...a strut tower is body integral. Which means it's a darn thick, strong piece of metal to support the body, take the hits that the struts try to help soak up etc. That's something that isn't going to be a thin cheap piece.
  16. #16 Re: Rusting rear strut towers
    texas
    I'm not up to speed on metal thickness, so were does 14 or 16 gauge steel stand in the thickness category
  17. #17 Re: Rusting rear strut towers
    PA
    14 gauge = .075" thk
    16 gauge = .060" thk
    2001 GSE
  18. #18 Re: Rusting rear strut towers
    texas
    Dude that's spanish to me, jus tell me is it thick or thin lol
  19. #19 Re: Rusting rear strut towers
    PA
    All depends on your point of perspective.
    If you are used to working with 1" thick metal all the time, that is thin. If you are used to working with .010" thick metal, that is thick. All depends on where you are looking at it from.
    2001 GSE
  20. #20 Re: Rusting rear strut towers
    texas
    Is it too thin for the application we are discussing is wat I'm asking
  1. Rear inner trunk rusting where the struts connect!
    By PTGsDaytona500GTP in forum Visual/Body Modifications
    Last Post: 04-28-2011, 10:06 AM
  2. Strut tower brace front and rear
    By SleeperGS in forum Brakes/Suspension/Chassis
    Last Post: 01-17-2011, 02:16 PM
  3. Cracks in Strut Towers
    By blkgp2000 in forum Brakes/Suspension/Chassis
    Last Post: 06-03-2010, 01:51 PM
  4. Need help with with rear strut mount??
    By 99GTP99 in forum General Tech Discussion
    Last Post: 02-18-2010, 08:27 AM
  5. missing spacer on rear strut mount '06 GXP
    By tta1401 in forum General Tech Discussion
    Last Post: 07-25-2009, 05:19 PM
