Thread: park brake lock up
Results 1 to 16 of 16
  1. #1 park brake lock up
    SE Level Member 04muscle's Avatar
    Dec 2008
    British Columbia
    When I put on my parking brake, the right rear one locks up and wont release for a few kilometers. found the rotor glowing red hot one night !!! ??
  2. #2 Re: park brake lock up
    Charles City, IA
    Probably time for a new caliper.
    SMGPFC Two Nipple General
  3. #3 Re: park brake lock up
    Never Never Land
    probably needs adjusted.
  4. #4 Re: park brake lock up
    Never Never Land
    isnt the ebrake a drum?
  5. #5 Re: park brake lock up
    Charles City, IA
    Its an integral parking brake for the 04 plus. the caliper piston twists out.
  6. #6 Re: park brake lock up
    Never Never Land
    didn't know that
  7. #7 Re: park brake lock up
    GT Level Member donmega's Avatar
    St louis, mo
    mine does the same thing. pretty sure its an adjustment. whatever you do dont drive it with it on. ur gona burn ur rotors and pads. next time keep a flat head in the car and get behind the caliper and snap it loose. ive had to do it 3 times all three during cold weather
    "well we can spend 1000s throwing parts in it and hope that fixes the problem or we can diag it correctly and change the .50 cent fuse...lets ask the owner what he wants to do" --Walt R.--
  8. #8 Re: park brake lock up
    SE Level Member MyPrixGT06's Avatar
    Weirton, WV
    I know this is an old post but I've searched and this is the closest to my problem.
    I know I should, but I dont look at my brakes that often (I do have yearly inspections). Recently looked at the rear rotors and found them to look like a vinyl record, divet lines in circles. So, I go to change the pads and rotors. After jacking it up I found it hard to turn the wheel. I get it all apart (rotor was stuck to hub), I'm having trouble getting the caliper to open fully. I broke a C clamp already (it was a cheaper clamp anyway but still..) thinking it is the ebrake I soaked the ebrake cable and spring with wd40 and got the spring arm to move where I think it should be but my clamp is now broken and will wait till tomorrow to get a new one.
    Am I missing anything else? This seems like a common issue but don't see much about the 04+ ebrake
    2006 Pontiac Grand Prix GT-
    180 tstat and intake.
  9. #9 Re: park brake lock up
    The piston doesn't push it it turns in with a special tool
  10. #10 Re: park brake lock up
    Weirton, WV
    Hmm.. Interesting. After googling it, is this it? OEM/Disc Brake Caliper Tool Set (27111) | Disc Brake Caliper Tool | AutoZone.com
  11. #11 Re: park brake lock up
    Thats what you need
  12. #12 Re: park brake lock up
    Weirton, WV
    Thats what you need
    cool thanks!! ill finish tomorrow. is there anythimg i can do to make sure the ebrake wont lock on me again? i dont see myself using it anymore 1 scared of it 2 selling it
  13. #13 Re: park brake lock up
    Only think you could do is lube up the cables.
  14. #14 Re: park brake lock up
    Weirton, WV
    I rented the tool and replaced the opposite side fine. I got the driver side piston in as far as I could and the ebrake cable is where it needs to be now. But after re assembling the tire doesn't spin freely when off the ground. Is this bad where I shouldn't drive it?
  15. #15 Re: park brake lock up
    Does it spin really hard or just a little resistance?
  16. #16 Re: park brake lock up
    Weirton, WV
    it was really hard then I pressed it a little more and now all seems well. stops on a dine like when I first bought it. thanks for all the help.
  1. Stuck In Park. Shift Lock Release Doesnt Work.
    By SilverGT in forum General Tech Discussion
    Last Post: 07-24-2012, 01:23 PM
  2. Push button for park-lock solenoid in column??
    By BLOWN93LX in forum General Tech Discussion
    Last Post: 04-05-2011, 12:10 PM
  3. park brake pads?
    By 1BlwnGTP in forum Brakes/Suspension/Chassis
    Last Post: 05-12-2010, 07:29 PM
  4. Doors dont lock when going into park??
    By Doerr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-24-2009, 11:39 AM
  5. Anti lock brake system electrical schematic?
    By thirdgenfcarnut in forum Brakes/Suspension/Chassis
    Last Post: 09-01-2009, 03:00 PM
