Thread: Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
Results 1 to 17 of 17
  1. #1 Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
    I am porting this from and another forum, but it has some very good information.
    Understanding the meaning of each part
    Toe:
    Toe is the relationship of the tires as viewed from directly above (or directly below, as the street sees them). 0 toe will have the tires absolutely parallel when rolling down the street. Most factory alignments use toe in, the tires are usually pointed in ever so slightly (usually 1/16th of an inch, give or take). With toe in, the steering needs to be turned enough to cause both tires to "point" the direction you want the car to go (as you turn the wheel, one wheel will remain pointed straight ahead while the other begins the turn....turn the wheel a little more and both wheels begin to make the turn....toe in tends to add stability to a vehicle....it makes the car less "twitchy"). With 0 toe, when the wheel starts to turn, the car will begin to turn as well, both wheels begin the turn together. 0 toe tends to make a car much more willing to initiate a turn. Toe out will do the same as 0 toe, but it goes a step farther...since the wheels are already pointed slightly out, the car is already "trying" to turn, it makes a car even less stable and more willing to turn (some cars will become very "twitchy" or "nervous").
    Camber:
    Camber is the tilt of the tires as viewed from directly in front of the vehicle (if you take 2 tires and stand them up in your garage and lay on the floor in front of them, they will likely be parallel, both standing vertically, which would be 0 camber). Negative camber is when the tops of the tires are closer together than the bottom of the tires, positive camber is when the tires are closer together at the bottom than the top (negative camber is / \, positive camber is \ / as the tires are viewed from the front) As a car begins to take a turn, the forces acting on a car begin to cause "body roll", during body roll, the front tires will begin to change the way the tire sits on the ground. As the body rolls, the contact patch on the road may be reduced (as the tire tilts away from the ground), to combat this, we add negative camber to the front suspension. Negative camber will help reduce the tendency to wear the outside edge of tires on cars that are driven hard through the corners. Negative camber will also help keep the contact patch of the tire flat on the ground during body roll. If you increase negative camber, you will begin to sear the inside edges of the tires when driving around (non-aggressively), since there is slightly more load on the inside edge than there is on the outside edge.
    Castor:
    The best way to describe castor is to look at a front wheel on a shopping cart, the carts front wheels stay straight due to castor. Castor is the angle of the point that the spindle rotates on when you turn the wheel. It is not straight up and down like you may think. The tire actually turns on a "tilted" axis. If you turn your wheels all the way to one side and look at them from in front of the car, you'll see that one is tilted in, and the other is tilted the same way (\\ or //), Now, if we have negative camber (with the wheels straight), how did we get negative on one side and positive on the other? That is castor at work. As you move the axis that the steering pivots on, you can get the steering to add negative camber when the wheel is turned. More or less castor will change the ultimate amount of negative camber "seen" by the road surface. It is a delicate balancing act....too much castor, you will have very "heavy" steering, too little and you'll lose cornering grip.
    Setting up for an alignment your way and best recommendations for our cars
    Camber:
    For street use, anything from -.5 to -1.5 camber is acceptable. Meaning, no evil handling characteristics, just progressively more grip as you head towards the -1.5 number (not all cars can get that high, I ran out of adjustment at -1.3). So, for street use (mild) we usually recommend -.5 to -.7 camber (as high as -1.0 for an "aggressive" street setup, people autocross on -1.3). We suggest a -.7 as a very good compromise for even better tire wear.
    Toe:
    For street use, 0 toe is good. Toe out makes the car more responsive (it wants to turn), because toe out makes it slightly unstable (not bad at all, think of balancing a ruler, standing straight up on your hand, it naturally wants to fall over, my car naturally wants to turn). 0 toe is a good compromise for street use. It makes the car slightly more responsive than it is now and it is still extremely stable.
    Castor:
    For street use we recommend +4.5, it keeps the steering from being too heavy and allows for a decent amount of negative camber while turning (go turn your wheels all the way to one side, notice that they are both "tilted" the same way, that's castor at work). We would not advise going lower than 4.3 nor higher than 5.0 and we really prefer 4.5 (as do many people). At 4.5 you'll have a stock steering feel, not too light and not heavier.
    Mild Street Alignment:
    0 Toe
    -.5 Camber
    +4.5 Castor
    Slightly More Aggressive:
    0 Toe
    -.7 Camber
    +4.5 Castor
    Even More Aggressive:
    0 Toe
    -1.0 Camber
    4.5 Castor
    The Full Race Setup
    1/32" to 3/32" Toe Out
    -1.3 to -1.5 Camber (whatever max is after the castor is set at 4.5)
    +4.5 Castor
    Each step will be slightly worse on tire wear and will be slightly more responsive and make more total grip than the one before it. For street use, any of the first 3 work great. If you really like to beat on it around cloverleaf type exit ramps, we suggest that you go with the 3rd setup. If you are just looking for something for a cruiser and weekend driver, the 1st or 2nd are both good setup. The 4th setup will make the car very responsive, but it may hunt on uneven pavement and be "darty" at times.
    The Above information is just to give you an example what going aggressive with a setup means. Here are the Ideal specs for OEM setup:
    Wheel Alignment Specifications
    Operation
    Service Allowable
    Service Preferred
    Front Suspension
    •Camber (Cross Tolerance)
    -1.40 to -0.40 Degrees
    -0.90 Degrees
    •Caster (Cross Tolerance)
    2.50 to 3.50 Degrees
    3.00 Degrees
    •Steering Angle
    -3.50 to +3.50 Degrees
    0 Degrees
    •Toe (Total)
    -0.10 to +0.30 Degrees
    0.10 Degrees
    Rear Suspension
    -0.90 Degrees
    •Thrust Angle
    -0.15 to +0.15 Degrees
    0 Degrees
    •Toe (Total)
    -0.14 to +0.26 Degrees
    +0.06 Degrees
  2. #2 Re: Understanding Alignment
  3. #3 Re: Understanding Alignment
    Donating User Odi's Avatar
    Chicago South Suburbs
    useful, but not relevant to grand prix. every car has different base alignment specs. and this is a bit different from a prix.
  4. #4 Re: Understanding Alignment
    actually the 'slightly more aggressive' is what is normally seen on a grand prix stock. im not sure about the caster, but the toe and camber are right.
  5. #5 Re: Understanding Alignment
    I loved driving with a total of 3* of toe out.
    The car was so willing to turn unlike it is now with -0.1* toe.
    I need my toe fixed but this sheet seems i'm already running an aggressive setup? Perhaps too much really?
  6. #6 Re: Understanding Alignment
    Pennsylvania
    This was maybe written by an F-body mechanic?
  7. #7 Re: Understanding Alignment
    GT Level Member ill12will8's Avatar
    DC/MD
    what does the sway bar have to do with the alignment
    1997 Artic White GTP: Stock (I call her "Brooke")
    2000 Silvermist GTP: ZZP DP, CAI w/ 9" open cone, Dorman front sway bar, PEMs, AL605 -DEAD & GONE
  8. #8 Re: Understanding Alignment
    Charles City, IA
    Nothing.
    SMGPFC Two Nipple General
  9. #9 Re: Understanding Alignment
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    camber is like a girls legs.. if they are \\ // its positive, if its // \\ its negative.
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  10. #10 Re: Understanding Alignment
    Grand Rapids, MI
    hahahha. so where was this alignment done? my alignment shop doesn't give me any kind of print out. :/
  11. #11 Re: Understanding Alignment
    they should. or they should at least tell you what they set it all at. fyi, if everything is at zero they just ****ed up your alignment.
  12. #12 Re: Understanding Alignment
    DC/MD
    I was told today that I couldn't be given a proper alignment but I have a broken sway
  13. #13 Re: Understanding Alignment
    If any suspension piece is broken most places wont align your car for you.
  14. #14 Re: Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
    SE Level Member 99FormulaM6r's Avatar
    May 2012
    I'm honestly a bit partial to some toe in (.06 degree or so, comes out to 1/16). 95% of the time you're driving your car, you're probably going straight, and it makes it track better. When you turn, to me it gives the illusion of adding some heft, not a bad thing IMO.
    -.5 camber, along with 4.5 or 5 caster is a must tho, so I do agree with the rest. To each their own I suppose.
    1999 Pontiac Firebird Formula M6: SLP lid, LS6 intake, GMMG catback, MGW, blanks/HPS/SS lines, Koni 4/4, Strano 35/22 sway bars, UMI PHB
    2001 Pontiac Grand Prix GT
    2007 Yamaha TW200
  15. #15 Re: Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
    a little bit of toe in is normal on most 'stock' alignments. you're right.
  16. #16 Re: Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
    Jan 2012
    Philadelphia
    toe*
  17. #17 Re: Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
  1. Help understanding the Cooling System.
    By genesis in forum General Tech Discussion
    Last Post: 12-29-2010, 12:47 PM
  2. Understanding electronics in our cars
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 12-16-2010, 10:10 AM
  3. PCM upgrading understanding
    By Lukus in forum PCM Tuning
    Last Post: 09-24-2010, 02:33 PM
  4. Am I understanding spark plugs right?
    By JDCMoney in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2009, 02:01 PM
  5. '01 alignment ?'s
    By riceburner in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 04:14 PM
