Thread: Swaybar Sizes
Page 3 of 11 FirstFirst 12345 ... LastLast
Results 41 to 60 of 219
  1. #41 Re: Swaybar Sizes
    SE Level Member hklvette's Avatar
    Jun 2010
    Christiansburg, VA
    Keep in mind that the 04-05 cars can get away with smaller front bars due to the better motion ratio offered by the direct-acting sway setup. In addition, the rear bar makes a much larger difference on these cars, and the Comp-G does have a bigger rear bar than the other GPs
    edit: Moog does make front links for our cars: K80852 Rockauto has them.
    '05 silver GTP, '98 Cherokee, '78 M880, '70 M35A2
    "Drag racing is for fast cars. Autocross is for fast drivers."
  2. #42 Re: Swaybar Sizes
    SE Level Member Aeroheadcww's Avatar
    Williamsburg, Ky
    Makes sense, the bars travel farther since the link attaches to the strut rather than further back on the LCA, which also explains why it handles so badly. It has to really lean into a curve before it stiffens up, when it leans in it really grabs but there is a zone in there between those extremes where it really floats around. Makes it feel like it is wandering back and forth all the time if you aren't really pushing it or the curve keeps changing pitch.
    Thanks for the expalnation, now that you said it it all makes perfect sense.
    EDIT: found out later that my handling problems were because of the rear hub bearings
    _____________________________________________
    '05 CompG - 3.6 Pulley, ZZP PCM, K&N drop in, Customized SD Headers, TEP Street/Strip tranny, ZZP STBs, ZZP Coilovers, GXP front brakes
  3. #43 Re: Swaybar Sizes
    Jul 2011
    st. louis
    Do these measurements pertain to a 2005 Base? I'm looking to replace the bushings on my 05 Base and Moog gives 3 different sizes for front bushings
  4. #44 Re: Swaybar Sizes
    im going to be changing out the front and rear bars, over the winter and im tryin to find out where to buy the dorman front bar, i looked on the dorman products website but didnt see anything about buying one
    SMGPFC Member #10
  5. #45 Re: Swaybar Sizes
    utah
    04 comp g's had the biggest of all irrc. I know its bigger then the gxp's.
  6. #46 Re: Swaybar Sizes
    GTX Level Member f3racer's Avatar
    dongducheon, south korea
    still no definate answer for the gxp's?
    SSG US Army Military Police
    2006 Grand Prix GXP
    http://gmls4.com
  7. #47 Re: Swaybar Sizes
    Donating User Odi's Avatar
    Chicago South Suburbs
    Quote Originally Posted by f3racer View Post
    i looked but couldnt find any info, would be nice if you could measure it and post it here
  8. #48 Re: Swaybar Sizes
    unfortunately i am stationed in korea without my car, but when i get back for leave next month i will measure it.
    2006 Grand Prix GXP
    http://gmls4.com
  9. #49 Re: Swaybar Sizes
    utah
    I can measure it next time I'm at my buddies
  10. #50 Re: Swaybar Sizes
    ok so this video says 17.5 mm hollow rear. i hope thats wrong, but they also say the front wheels are 7" wide and the rears are 8".
    Motorweek Video of the 2006 Pontiac Grand Prix - YouTube
    2006 Grand Prix GXP
    http://gmls4.com
  11. #51 Re: Swaybar Sizes
    2006 Grand Prix GXP
    http://gmls4.com
  12. #52 Re: Swaybar Sizes
    GTP Level Member joshv's Avatar
    canada
    Will the compG bars work in the GXP
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  13. #53 Re: Swaybar Sizes
    if so im going to be looking for some
    2006 Grand Prix GXP
    http://gmls4.com
  14. #54 Re: Swaybar Sizes
    utah
    yes they will. but the 04 bar is bigger then the 05
  15. #55 Re: Swaybar Sizes
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    Part number for the 04-05 Comp G front sway bar is 10346886. GMpartsdirect just says STRUT, no info. The part number for the stock 04-05 front sway is 10342300.
    Both these bars felt like they weighed the same, I only noticed a difference because I put the thicker Moog endlinks on.
    Moog K6662 is the Rear, K80852 is the front, they are pretty cheap on rock-auto.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  16. #56 Re: Swaybar Sizes
    GT Level Member Xanthous's Avatar
    Apr 2011
    St. Louis
    SLP Sway Bars (Front and Rear Set): 3800 Performance
    says slp rear is 19mm, not 25mm?
    what's the specs on the 04 comp g rear sway? upgrade to the 00 rear sway?
  17. #57 Re: Swaybar Sizes
    Harrisville, Utah, United States
    my factory sway bar broke and i need a new one but my headers are hitting on the old one any suggestions?
  18. #58 Re: Swaybar Sizes
    Quote Originally Posted by Xanthous View Post
    i run slp's and its got 25mm in the rear.
  19. #59 Re: Swaybar Sizes
    Oct 2011
    Puyallup WA
    I measured my 04 comp g rear bar last weekend and it measured at about 20mm that was right over near the endlink
    08 G8 GT - exhaust Tune
  20. #60 Re: Swaybar Sizes
    ^^ thats consistent with gmpp sway kit, which is 19mm solid. i always thought thats what comp g's got.
  1. Swaybar Brackets...
    By Odi in forum Brakes/Suspension/Chassis
    Last Post: 11-13-2009, 01:07 PM
  2. Busted Front Swaybar
    By Pontiac Warrior in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 01:33 AM
  3. Largest available rear swaybar?
    By DanGTP in forum Brakes/Suspension/Chassis
    Last Post: 04-29-2009, 10:02 PM
