Thanks
Have you checked BMR?
So is there a good place to get a rear sway bar? I want something thicker than the ones zzp offers.
I believe the doorman are thicker than the bar ZZP sells which is a GMPP. Check out RockAuto Parts Catalog
So I just received my SLP sway bars from UPS today. The rear bar is definitley NOT 25mm. I'd say it's closer to 19-20mm. I didn't have time to measure them before leaving for work. Also I'd say the front is actually 34mm and not 35. The 35mm bushing I have for it did not fit snug around the bar but had about a 1mm gap. Maybe that's normal and there's suppose to be that much room. I thought it was suppose to be pretty snug around the bar though. If the front is 34mm and the rear is as small as I think I'm going to be returning them and buying other bars.
ok i have a rat rear swaybar and im hearing noise back there when i go over bumps i put it up on the lift and there is play in the swaybar when i move it, so im guessing i need new bushings or endlinks? can i still get them somewhere or do i have to buy a different swaybar?
Just buy end links off rock auto
You if my memory serves me correct for rears...just the end links should be all u need as long as ur sway bar isn't cracked
Hold on I'll post link. What's ur year make and model
if you have a 97-03 you need 2x Moog k6662 end links for the rear. If you need new bushings just find some poly ones with the corrects dimensions which I believe are 27mm.
Search that part number on rockauto
O u ninjad me
haha sure did. Just did mine so had the part number handy still.
I don't have a gtp so I had to look it up
