Thread: Swaybar Sizes
Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 101 to 120 of 219
  1. #101 Re: Swaybar Sizes
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Thanks
  2. #102 Re: Swaybar Sizes
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Have you checked BMR?
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  3. #103 Re: Swaybar Sizes
    Buffalo, NY
    From everything I read and looked for they're not being made anymore. you can still find their stbs and trailing arms etc. but the sways are discontinued.
  4. #104 Re: Swaybar Sizes
    Banned
    Jan 2013
    Colorado
    So is there a good place to get a rear sway bar? I want something thicker than the ones zzp offers.
  5. #105 Re: Swaybar Sizes
    Buffalo, NY
    I believe the doorman are thicker than the bar ZZP sells which is a GMPP. Check out RockAuto Parts Catalog
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  6. #106 Re: Swaybar Sizes
    Buffalo, NY
    So I just received my SLP sway bars from UPS today. The rear bar is definitley NOT 25mm. I'd say it's closer to 19-20mm. I didn't have time to measure them before leaving for work. Also I'd say the front is actually 34mm and not 35. The 35mm bushing I have for it did not fit snug around the bar but had about a 1mm gap. Maybe that's normal and there's suppose to be that much room. I thought it was suppose to be pretty snug around the bar though. If the front is 34mm and the rear is as small as I think I'm going to be returning them and buying other bars.
  7. #107 Re: Swaybar Sizes
    SE Level Member 1HOTGTP's Avatar
    IOWA
    ok i have a rat rear swaybar and im hearing noise back there when i go over bumps i put it up on the lift and there is play in the swaybar when i move it, so im guessing i need new bushings or endlinks? can i still get them somewhere or do i have to buy a different swaybar?
  8. #108 Re: Swaybar Sizes
    I live here. DirtDog's Avatar
    Jun 2012
    Just buy end links off rock auto
  9. #109 Re: Swaybar Sizes
    IOWA
    ok so i just need to get the 27mm ones then?
  10. #110 Re: Swaybar Sizes
    Jun 2012
    You if my memory serves me correct for rears...just the end links should be all u need as long as ur sway bar isn't cracked
  11. #111 Re: Swaybar Sizes
    IOWA
    cant find them
  12. #112 Re: Swaybar Sizes
    Jun 2012
    Hold on I'll post link. What's ur year make and model
  13. #113 Re: Swaybar Sizes
    Buffalo, NY
    if you have a 97-03 you need 2x Moog k6662 end links for the rear. If you need new bushings just find some poly ones with the corrects dimensions which I believe are 27mm.
  14. #114 Re: Swaybar Sizes
    Jun 2012
  15. #115 Re: Swaybar Sizes
    Jun 2012
    Search that part number on rockauto
  16. #116 Re: Swaybar Sizes
    Jun 2012
    O u ninjad me
  17. #117 Re: Swaybar Sizes
    Buffalo, NY
    haha sure did. Just did mine so had the part number handy still.
  18. #118 Re: Swaybar Sizes
    Jun 2012
    I don't have a gtp so I had to look it up
  19. #119 Re: Swaybar Sizes
    IOWA
    ok great thanks, where can i get the new 27 mm bushings
  20. #120 Re: Swaybar Sizes
    IOWA
  1. Swaybar Brackets...
    By Odi in forum Brakes/Suspension/Chassis
    Last Post: 11-13-2009, 01:07 PM
  2. Busted Front Swaybar
    By Pontiac Warrior in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 01:33 AM
  3. Largest available rear swaybar?
    By DanGTP in forum Brakes/Suspension/Chassis
    Last Post: 04-29-2009, 10:02 PM
