Thread: Discussion on wheel hubs
Page 4 of 4 FirstFirst ... 234
Results 61 to 69 of 69
  1. #61 Re: Discussion on wheel hubs
    Donating Users dirtmaster88's Avatar
    Sheboygan, WI
    Quote Originally Posted by Gorecki View Post
    Crap, my network won't let me see your pictures but I had a hell of a time with one of them being seized on my '05 but I learned my lesson and WD-40'd the hell out of the other front the night before and was MUCH easier.
    Sad part is I actually bought a removal tool and there was no way in hell that thing was going to get the bearing off! So now it sits, unused on the shelf. Stuff we learn the hard way!
    ya i also used 1/2 can of pb blaster. Although I didn't let it sit more than 1/2 hour at a time, I think it still helped. A friend of mine suggested pb blaster and letting it sit a few days then hit it again and keep doing the same process for a couple weeks then try doing the repair. He also suggested just taking the cv halfshaft out with the bearing still on it and using a press to get it off. Either way, I honestly think it was worth the extra $60 to get a new cv halfshaft and just replace the whole ****. Was a $60 well spent IMO.
    2004 GTP CompG - 3.6" ZZP MPS, K&N CAI, 180* Tstat, SSAC Headers, ZZP Flex, high flow cat, borla exhaust, DHP/danthurs tune, AL104s, ZZP Wires, alt re-wire, slotted/drilled rotors, 35% tint, alpine amp + sub
  2. #62 Re: Discussion on wheel hubs
    Charles City, IA
    Why on earth did you need a cheater pipe that long?
    SMGPFC Two Nipple General
  3. #63 Re: Discussion on wheel hubs
    Sheboygan, WI
    lol was the only pipe aside from pvc lying around at the time. was pretty thin pipe though ended up bending the pipe lol
  4. #64 Re: Discussion on wheel hubs
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    wow wtf...my 06 wasn't nearly that hard...
    Just did mine 2 days ago, though I forget to put the torque wrench on it...Doh!...I just got down on it with a 1/2" drive.
    So bearing failures is due to over-tightening? Anyone got a torque spec?
    I may need to tear mine back down just to check that spec, think it's still salvageable?
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  5. #65 Re: Discussion on wheel hubs
    Largo, Florida, United States
    Tried to do my 98 (that was a FL car btw) had a breakerbar and all... no ****ing luke. 1/2 of PB plaster soaked in over night still no luck
    going to use my buddys Air gun in a few days
  6. #66 Re: Discussion on wheel hubs
    Aug 2008
    Fayetteville, NC
    yeah if a impact wrench still doesnt get it...keep pushing on it with the gun...the severe vibrations from the impact wrench may just be what it needs to loosen up.
  7. #67 Re: Discussion on wheel hubs
    SE Level Member Gorecki's Avatar
    Nov 2010
    Maryland, US
    Quote Originally Posted by offroadfury6 View Post
    From memory (slightly fading)
    front bearing nuts are ~90 ft lbs
    axle nut is 118 ft lbs
    rear bearing nuts are ~70 ft lbs
    my guess is yours being in southern NC hasn't seen as much bad weather and road salt as others have. When doing my rears I had to scrape out packed salty crude that had been in there for gosh knows how long (at least a year, likely more).
    [TRADED] 2005 Grand Prix Silver
    K&N Air Filter, NGK TR55GP G-Power Plugs, Delphi OE Wires, Timken Bearings, Mobil 1 Synth ATF & Oil, Purolator PureOne Filter
  8. #68 Re: Discussion on wheel hubs
    Aug 2008
    Fayetteville, NC
    good point on the southern NC thing =P...havent seen salt on the roads in ages...or never
  9. #69 Re: Discussion on wheel hubs
    Sheboygan, WI
  1. Strut discussion
    By Warbeaver in forum Brakes/Suspension/Chassis
    Last Post: 05-02-2010, 12:15 AM
  2. felling up for a discussion about drivtrains
    By undecided in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-15-2010, 11:34 AM
  3. New Wheel Hubs
    By Mohatmus in forum Brakes/Suspension/Chassis
    Last Post: 11-08-2009, 09:55 PM
  4. I want these rims but they wont fit, new wheel hubs?
    By Quicklynx in forum Tires & Wheels
    Last Post: 07-16-2009, 02:04 PM
  5. Wheel Bearings/Hubs
    By bcrosby51 in forum General Tech Discussion
    Last Post: 09-15-2008, 01:49 PM
