Thread: The Big Bad Brake Thread
Page 32 of 33 FirstFirst ... 2230313233 LastLast
Results 621 to 640 of 647
  1. #621 Re: The Big Bad Brake Thread
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by Sudden View Post
    Won't fit, can't space it out enough.
    Yeah comp G rotors are 11.6". Not sure why those wheels won't fit but maybe because of the spokes.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  2. #622 Re: The Big Bad Brake Thread
    Houston/Baton Rouge
  3. #623 Re: The Big Bad Brake Thread
    Slower, Lower Delaware
    I'm going to give her the CompG wheel set. I'm looking for a set of ultra light wheels for my car now.
  4. #624 Re: The Big Bad Brake Thread
    Houston/Baton Rouge
    Sounds good.
  5. #625 Re: The Big Bad Brake Thread
    Will GXP wheels fit my car with no problems?
  6. #626 Re: The Big Bad Brake Thread
    Yup
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  7. #627 Re: The Big Bad Brake Thread
    Aug 2016
    Norfolk, VA
    I read every page (or close enough) of this thread and didn't see anyone once mention the mod for the f-body brackets to fit.
    Bear in mind that this was on my 07, other gens/years *may* be different, but the mounting holes in the f-body caliper bracket need to be drilled out with a 12mm (15/32nds will do it) and then tap these holes to M14-2.00 to accept the stock GP bracket bolts. It really isn't difficult because the brackets are aluminum.
    Also, in case anyone is considering this mod still (I know there are A LOT of different options out there now), the ZZP kit really isn't that bad for the price. I picked up a used set off a '99 Camaro on CL for $50. The pistons ended up being trash, RTV on the seals (?) and rusted to crap. I ended up using them as cores for a new pair at Advance, saved myself twice what I paid for them right there (core charge is $50/each!). Add in decent pads and both rotors and you're basically at ZZP's price. (I don't work for them or anything, just an FYI based on my experience piecing everything together and modding the brackets myself). You still have to paint them, though, lazy bums.
  8. #628 Re: The Big Bad Brake Thread
    GT Level Member bachert24's Avatar
    Jan 2015
    I'm looking to upgrade my comp G to gxp calipers on the front. I know I need gxp calipers, rotors, and pads. Anything else? Will the gtp lines, bolts, and brackets work with the gxp upgrade? I'm starting to collect parts. I'll probably go with SS lines anyways.
    Sent from my LGLS992 using Tapatalk
  9. #629 Re: The Big Bad Brake Thread
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Quote Originally Posted by bachert24 View Post
    I believe the brackets need to be GXP, but everything else should be the same. If you want to upgrade further, get the R1 concepts rotors and pads off Ebay, they stop like no others.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  10. #630 Re: The Big Bad Brake Thread
    Jan 2015
    Quote Originally Posted by WarStryker13 View Post
    Thanks!
  11. #631 Re: The Big Bad Brake Thread
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Ok Ok.... So I recently bough some 2007 Impala brakes and I'm confused as to which rotors I need. Should I be looking for stock GTP size rotors? Impala rotors? Do I upgrade to a bigger size rotor with these new '07 calipers?
    I scanned through this post, and there's A LOT to read, but still not sure. Thanks
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  12. #632 Re: The Big Bad Brake Thread
    Antioch, IL
    you need impala rotors 06+
    2009 Challenger SRT8
    Expert at being gay.
  13. #633 Re: The Big Bad Brake Thread
    Dec 2015
    Chicago, IL
    ^^ Thanks for the quick response, Corey. Impala R1 rotors it is....
    243,000 miles
    CHICAGO, IL
  14. #634 Re: The Big Bad Brake Thread
    Nov 2012
    Madison
    Finally decided to do the Powerstop 06 Impala calipers&brackets, rotors and pads for my 2004 compg
    Since I was doing that I decided it was a good thing to get new Hoses. Aftermarket 2004 OEM AC Delco professionals don't fit.
    The hard line off the caliper hits the bleeder. You would have to notch the caliper with a grinder. Nah.
    I ordered the 06 Impala hoses, AC Delco professional hoses. They fit perfect of course on the caliper but the fender well bracket end has a bubble flare in the female end, opposite of the GP.
    This won't work with the GP hard line off the master without some modding, new fittings and some flares.
    Too much dinkin around.
    Well after spending 80+ dollars on useless hoses(out of the box) I should have just went with the stainless Goodridge lines......ordering today. save a penny spend a dollar, damn
    Moral is> if you are replacing hoses you will need the Goodridge lines for the 2004+ anyway unless someone knows some other kind of voodoo.
  15. #635 Re: The Big Bad Brake Thread
    Spazzz, Goodrich is what I did when I went to the F-body calipers. I'm hoping they'll still be ok when I upgrade again.
  16. #636 Re: The Big Bad Brake Thread
    Nov 2012
    Madison
    I always have to have my ducks in a row before I start wrenching.
    I would have been one pissed off mutha had I not mocked this sht up.
    now I know why guys install them on the wrong side because that way they would fit no problem with a new GP hose.
    edit
    I would imagine the 06 Impala hoses would work with the 06 Impala calipers on an 04 with the proper adapter but I haven't been able to figure that one out yet.
  17. #637 Re: The Big Bad Brake Thread
    I did that.
  18. #638 Re: The Big Bad Brake Thread
    Houston/Baton Rouge
    Quote Originally Posted by spazzz View Post
    ZZP lines would have worked too.
    When I had the 06 Impala calipers on my Regal. I had to angle the lines because of that notch on the calipers.
    and that's pretty awesome powerstop makes a kit already power coated and everything.
    https://www.summitracing.com/parts/p...8/applications
  19. #639 Re: The Big Bad Brake Thread
    Jan 2015
    Quote Originally Posted by Ridin ON Chrome View Post
    ZZP lines are goodridge
    Sent from my LG-LS993 using Tapatalk
  20. #640 Re: The Big Bad Brake Thread
    Nov 2012
    Madison
    Yeah, I ordered a set of Goodridge from those ZZP guys.
  1. brake parts to get for brake upgrade??
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 01-03-2011, 08:59 PM
  2. Another with these fit, what do you think thread!!!
    By kjclawson in forum Tires & Wheels
    Last Post: 08-03-2010, 08:35 AM
  3. ^ thread
    By GreenPrix in forum Off Topic Discussion
    Last Post: 01-02-2010, 11:58 PM
  4. My car pic thread
    By thelongone13 in forum Off Topic Discussion
    Last Post: 02-11-2008, 11:23 AM
