Thanks Matt.
Ok so can you guys help me out with my shopping list?
I know i need these:
C5 calipers
F body brackets and pads
12" rotors
New brake lines (not necessary?)
I know i will need to tap the brackets.
What else am i missing?
KTHXSTAY
C5 pads, not F body.
Yay more expensive brake pads.
12" rotors from F body.
Hey guys any idea what this is?
a guide pin with the rubber pin pried slightly off.
no.
only one pin will have that rubber guide.
the other pin will be solid.
Do you know which hole the guide pin hole is supposed to go in? The top or the bottom?
unsure, haven't had brakes off in a while.
will soon though.
Ok well that helps out a bit thank, anyone else know which hole has the guide pin?
How does one use F body pads with C5 calipers?
f-body brackets. thats why. youd know if you didnt cheap out on teh brakes.
:facepalm:...oh matt
Nothings wrong with them...just want go bigger.
Looking to replace my pads and rotors. I have the F- body swap! Any suggestions what I should get? Id like to get drilled rotors. Not laced ones.
Also. A good site that any of u know of to buy said rotors and pads!
You could buy street perf pads from centric and premium rotors from centric via Rock auto.
or Hawk HPS pads/EBC Red pads, or try racing brake rotors, Pricey but they're curved veins.
