Note all torque numbers are effectively useless except for relative comparative purposes.
This is because the brake proportioning valve rates are unknown.
2003 Pontiac Grand Prix - Specs, Specifications, Data
GTP curb: coupe: 3495 sedan: 3559
weight dist: 65/35
Rotor diameter (in / mm) front: 10.9 / 277; 10.9 / 277
Front force
Tw = 458.85 joules
Rear force
Tw = 346.85 joules
total 805.7 joules
f/r as percent
57/43
2005 Pontiac Grand Prix - Specs
S/C curb: 3583
weight dist: 62/38
Rotor diameter (in / mm) front 11.7 / 297
rear 10.5 / 270
Front force:
Tw = 492.01 joules
Rear force:
http://www.caranddriver.com/var/ezfl...f42798e242.pdf
GXP time
curb: 3632
Dist: 63.8/36.2
Front . . . . . . . . . . . . . 12.7 x 1.3-in vented and cross-drilled disc
Rear . . . . . . . . . . . . . . 12.0 x 1.0-in vented and cross-drilled disc
Front force: Tw = 755.60 joules
Rear force: Tw = 332.97 joules
Total: 1 088.57 joules
Dist: 69/31
Thus far: confusing to say the least.
2005 Chevrolet Impala - Specs, Data
SS: 3606
weight dist: 61 / 39
Rotor diameter x thickness (in / mm) front: 11.93 x 1.26 / 303 x 32
rear: 10.9 x .43 / 278 x 11
Front force:
Tw = 500.11 joules
Rear force:
Tw = 346.85 joules
Total: 846.96
Dist (F/R)
59%/41%
2009 Buick LaCrosse - Specs
2009 W body...
Curb: CXL (L26) 3502
Super (LS4) 3770
Weight dis: n/a?
Rotor diameter x thickness (in / mm) Front CX, CXL 11.7 x 1.26 / 297 x 32
Super 12.72 x 1.18 / 323 x 30
Rear CX, CXL 10.6 x 0.55 / 270 x 14
Super
10.94 x 0.43 / 278 x 11
Front force:
CXL:
Super: Tw = 755.60 joules
Rear force:
CXL:
Super: Tw = 332.97 joules
Total:
CXL:
Super: 1 088.57 joules
Dist:
CXL:
Super: 69/31
