Thread: Alignment
Results 1 to 4 of 4
  1. #1 Alignment
    Would you go back to have it fixed with these numbers?
    First caster/caster/toe is front and second camber/toe is rear and thrust angle is well... thrust angle.
  2. #2 Re: Alignment
    i like to run toe as close to zero as possible. i also think the camber is fine.
  3. #3 Re: Alignment
    I think i'd like to get the toe and thrust angle fixed...
    Pulls every so slightly to the right.
  4. #4 Re: Alignment
    Jul 2010
    upstate NY
    Toe is adjustable, caster usually not. But before chasing anything further for that slight pull to the right, swap the front tires (if they are not directional or back to front if they are) to make sure it isn't the tires causing the pull.
    I wonder why they couldn't get the front toe better balanced? Go with the camber you got. I'm running ~-0.7 on the fronts and ~-1.5 backs after a strut job with no tire wear issues.
  1. Headlight alignment
    By coreygnar in forum General Tech Discussion
    Last Post: 05-19-2010, 03:43 PM
  2. Alignment kits?
    By Amb4 in forum Brakes/Suspension/Chassis
    Last Post: 04-22-2010, 04:13 PM
  3. Wheel alignment
    By kissmyss in forum General Tech Discussion
    Last Post: 04-19-2010, 12:13 PM
  4. alignment specs.
    By stlmo_gtp in forum Brakes/Suspension/Chassis
    Last Post: 07-21-2009, 02:40 PM
  5. '01 alignment ?'s
    By riceburner in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 04:14 PM
