Yes, while banging the hell out of an axle to get it from being seized to the wheel hub I caused a problem with the threads.
The axle was seized on the hub hard enough after a few fruitless attempts what got it off was part of a can of WD40 and ~20ish pretty hard whacks with a 4 lbs sledge hammer..and then I was still getting worried it wasn't going to come loose. But it finally did.
But now, I've whacked it hard enough I literally flattened the end of the axle a bit and the end started to expand in diameter as well as the first round of threads crushed in ever so slightly. Honestly, for as hard as I was hitting, I hit on target and square, but now the axle nut won't start threading back on.
So I'm looking for some suggestions for getting the nut back on outside of completely replacing the entire axle assembly. The thread damage is really minor so I've thought of :
Getting an air rachet and seeing if it will get the threads to bite (having doubts).
Getting my hands on a grinder and simply grinding down a small area of the outer edges of the axle making it smaller at the end. That way maybe I can get into the next round of threads that haven't been squished?
Any thoughts or suggests by those with greater experience on this little mess I've created?
Help would be greatly appricated as my car is on a stand until I get this fixed.![]()
