Thread: Vibration at highway speeds
Results 1 to 11 of 11
  1. #1 Vibration at highway speeds
    Aug 2008
    KCMO
    so i have had a vibration for some time now at speeds of 55-70 under acceleration. i replaced the outer tie rod ends, got an alignment, the tires and both half shafts and its still there. what could it possibly be?
  2. #2 Re: Vibration at highway speeds
    does it hum too??
    maybe a bad hub
  3. #3 Re: Vibration at highway speeds
    Aug 2008
    KCMO
    no hum. wheel hubs are pretty straight forward on signs of being bad
  4. #4 Re: Vibration at highway speeds
    SE Level Member Whiplash Performance's Avatar
    Hillsborough, NJ
    Had the same issue with mine, the bottom passenger side motor mount, the nuts loosened up and one actually fell out. I tightened it back up and the issue went away.
    Whiplash Intense Performance Hillsborough, NJ
    Performance Parts & accessories| Powder Coating | Engineering
    Intensewhiplash.com
  5. #5 Re: Vibration at highway speeds
    Aug 2008
    KCMO
    thats the only thing i can think of is motor or tranny mounts now
  6. #6 Re: Vibration at highway speeds
    GT Level Member backinblackgtp's Avatar
    Nov 2009
    centereach, NY
    i have the same problem anywhere from about 50 mph til 65 the car vibrates, when you have passengers in your car do they feel it? or is it driver seat only. i wasted so much money replacing bearings, hubs, balancing wheels, i was told i had bent rims (which i didnt) CV axels, and it still didnt stop. finally i bring it to a good mechanic he tells me which i cant remember the exact word, but its like they are clips on the end of the axels that either bent, or fell off (almost like little pins) which causes a vibration. But it's not even worth fixing he told me since its not dangerous at all, and it goes away after 70 mph.
  7. #7 Re: Vibration at highway speeds
    Aug 2008
    KCMO
    ya you can feel it in the whole car and its in the steering wheel.
  8. #8 Re: Vibration at highway speeds
    Nov 2009
    centereach, NY
    ya my steering wheel does the same thing, it gets really annoying but it comes down to... do you really wanna spend the money fixing something that isnt dangerous and doesnt effect performance/handling? its pointless and its over 200 to fix, atleast for me it was.
  9. #9 Re: Vibration at highway speeds
    Aug 2008
    KCMO
    i would rather pay to have it fixed then deal with the annoying vibration. and i dont want it wearing out my tires
  10. #10 Re: Vibration at highway speeds
    Nov 2009
    centereach, NY
    ya than get it fixed. how many miles are on your car, and it wont wear out your tires. Do you do alot of burnouts? because thats what can cause it especially if your wheel isnt straight
  11. #11 Re: Vibration at highway speeds
    Aug 2008
    KCMO
    104k. i have brand new tires on the car and i have dont e few burnouts but they were all straight
  1. Car dies at idle or low speeds
    By mikejon in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-17-2013, 10:44 AM
  2. Vibration when hitting the brakes at speeds above 30mph
    By IFrees in forum Brakes/Suspension/Chassis
    Last Post: 09-15-2010, 06:59 PM
  3. Shutter while downshifting at highway speeds (50 to 65 MPH)
    By GPdude97 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-23-2009, 02:52 PM
  4. Lost all Heater Fan speeds
    By SuperChargedGTP in forum General Tech Discussion
    Last Post: 07-24-2009, 07:37 AM
  5. vibration at highway speeds
    By dagger in forum Brakes/Suspension/Chassis
    Last Post: 05-25-2009, 07:42 PM
