Thread: grinding noise on turn
Results 1 to 11 of 11
  1. #1 grinding noise on turn
    mi
    hey guys, i have a grinding noise that just developed yesterday. If I take a hard left turn or cut the wheel to a hard left while pulling into a parking stall a loud grinding noise occurs. I did a quick search online and it was suggesting possible CV joint issues. I'd like to get GP expert advice so I posted here. I have an '04 GTP Comp-G if that helps.
    Any thoughts?
  2. #2 Re: grinding noise on turn
    Windsor (ON) Canada
    Might be a bad Right HUB assembly.
  3. #3 Re: grinding noise on turn
    Charles City, IA
    99% on the right front wheel bearing.
    SMGPFC Two Nipple General
  4. #4 Re: grinding noise on turn
    SE Level Member timmysgtp's Avatar
    Jul 2010
    marrero louisiana
    Could be bearing in your cv shaft. But it could also be your wheel bearing Jack the car up on the side that the noise is comin from,and try to wiggle the rim top to bottom if it has alot of play it's your wheel bearing
  5. #5 Re: grinding noise on turn
    Willoughby, Ohio
    wheel bearing or CV
  6. #6 Re: grinding noise on turn
    mi
    Thanks guys. I appreciate the initial assessments based on my minor description.
    TimmysGTP, I'll give that test a try to see if it is indeed the wheel bearing.
  7. #7 Re: grinding noise on turn
    Charles City, IA
    Just because the bearing does not have play in it does not mean it wont be noisy.
  8. #8 Re: grinding noise on turn
    Windsor (ON) Canada
    Mine never had play when my HUB was broken.. I going to guess that any "play" would mean that your HUB is completely destroyed. I could still drive fine but when turning left (like wade described) my front right would make a noise..
  9. #9 Re: grinding noise on turn
    Windsor (ON) Canada
  10. #10 Re: grinding noise on turn
    Jul 2010
    marrero louisiana
    ok got you.. Mine just never made noise until it was completley bad so I didn't notice it..
  11. #11 Re: grinding noise on turn
    Charles City, IA
    noise means the grease in them is gone, no grease leads to complete failure of the hub.
  1. new grinding noise
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2010, 08:07 AM
  2. Grinding noise when driving around
    By littlerobinson75 in forum Brakes/Suspension/Chassis
    Last Post: 08-08-2010, 10:34 AM
  3. Right-Front Grinding Noise
    By cowmilker08 in forum General Tech Discussion
    Last Post: 06-07-2010, 01:36 PM
  4. grinding noise in reverse
    By wrathofthunder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 08:24 PM
  5. Grinding noise coming from my engine
    By zeppelinrocks18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 04:24 PM
