Thread: Cutting bumpstops...inform me
Results 1 to 7 of 7
  1. #1 Cutting bumpstops...inform me
    GTX Level Member real diehl's Avatar
    Salina, KS
    So I just got my Springtech springs in today and there was no paperwork regarding cutting of the bumpstops.
    I know with Eibach's you cut 20mm off the front one but I'm not even sure what you're cutting.
    Is it in the mount or the rubber deals in between the spring and the strut?
    Thanks
    signature removed for inappropriate content.
    -bio
  2. #2 Re: Cutting bumpstops...inform me
    this is a picture of some bump stops:
    now, you may not need to cut yours. run them for a while and see if your car rides on them or not. when you hit your bump stops you'll feel like the car is bottoming out. if that is the case, trim the bump stop a little and see if it still reacts the same.
    the problem with trimming the bump stops is that the bump stop helps to make large bumps less harsh. the more you trim it, the more harsh a bump will be when it ends up hitting the bump stop.
    good luck, let me know what you figure out and maybe ill add it to the lowering thread.
  3. #3 Re: Cutting bumpstops...inform me
    Salina, KS
    Thanks bio at least now I know what I'm looking for.
    Between the right and left do you know if they are top and bottom or are they front and rear?
    Also do you know if you cut the tapered part or the flatter part?
    -bio
  4. #4 Re: Cutting bumpstops...inform me
    im not 100% sure, so dont quote me.
    i believe you would cut the non-tapered end because the tapered end faces down and stops the struts movement upwards. therefore, you leave the tapered end to contact the strut body alone and just shorted the overall area it covers.
  5. #5 Re: Cutting bumpstops...inform me
    Dec 2008
    Lawndale, CA
  6. #6 Re: Cutting bumpstops...inform me
    very nice, guz.
    that should be what youre looking for diehl
  7. #7 Re: Cutting bumpstops...inform me
    Salina, KS
    very nice, guz.
    Yep. Thanks guz
    -bio
  1. Head gasket???Please inform meee.Locked up
    By PWNED in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-07-2009, 10:08 AM
  2. weird noise cutting out
    By 01gtpfargo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2009, 12:27 PM
  3. Cutting S/C gaskets for S2 Intercooler
    By kamper98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2008, 05:26 PM
  4. ses codes and car cutting out
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2008, 12:33 PM
  5. Car Cutting out
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-31-2008, 04:48 PM
