Thread: Brake line question
Results 1 to 3 of 3
  1. #1 Brake line question
    massachusetts
    Hi, I am about to replace the rear brake lines on my daughter's '00 Grand Prix. I was under there figuring out how much line I am going to need, and spraying fittings with PB blaster.
    Does anyone know off the top if their head what thread size, and what type of flare the lines are where they connect to that fitting near the end of the line? I was going to disconnect it, but figured I should let the PB Blaster soak in first. I think it's a metric/bubble flare, but not sure.
    Thanks.
  2. #2 Re: Brake line question
    Might want to consider the fuel lines as well. If you take one out, you could accidentally take them all out.
  3. #3 Re: Brake line question
    Charles City, IA
    Good trick to getting the fitting off is to cut the line right behind it and then use a socket on it. I am pretty sure the grand prix still use the metric flare. I would leave the old line in and just run the new one right next to it to avoid braking any more lines.
    SMGPFC Two Nipple General
  1. Front to rear brake line replacement - need advice
    By bxfl in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2010, 09:56 AM
  2. Fbody brake line question
    By minichopper6hp in forum Brakes/Suspension/Chassis
    Last Post: 05-09-2009, 05:00 PM
  3. ZZP's 5th Stainless Brake Line!!
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-17-2008, 06:06 PM
  4. 5th brake hose -hard line solution ~$6
    By alacran in forum How To Write-Ups/Tech Tips
    Last Post: 10-02-2008, 08:18 PM
  5. brake line fitting ?
    By quiksilvergt in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 06:42 PM
