My front sway bar snapped on my 2000 gtp and i unbolted it and all but i cant just slide it out. Any ideas?
Take off the end links and bushings then work it out from the side. It will come out when you get the right angle. I swapped mine and it came out that way. I had the lower control arms off at the time to put new ones in. Maybe that made it easier.
Twist pull twist pull pry pull twist swear pull pry it will come out. All you need are the tires off.
make sure you jack you car as high as you can. Makes it a lot eaiser to get the sway bar out and in
