Thread: AGX vs GR-2
Results 1 to 19 of 19
  1. #1 AGX vs GR-2
    Nov 2008
    Chicago
    How do the AGX's on the lowest setting compare to the GR-2's as far as ride quality goes?
    Also, many people have stated that the GR-2's will wear out quickly with drop springs. The Eibach springs have a 1.3" drop in the front. If I where to get the GR-2's 1.3" shorter than stock, would I have the same issue?
  2. #2 Re: AGX vs GR-2
    Donating Users Warbeaver's Avatar
    St. Louis
    yes, lowering springs on GR-2s is harder on them. it CAN shorter the life expectancy. You will find on here that SOME people have had lowering springs on GR-2s with no problems, however, there are MANY people that have had the struts go out at 10k, 15k, or 20k miles, usually those with lowering springs. AGXs are, by far, a better strut and you should get them if you plan on lowering. They will last you longer, feel better, and you can adjust their firmness whenever you want.
    I plan on getting GR-2s in the future using stock springs. They seem to do fine that way.
  3. #3 Re: AGX vs GR-2
    eibach springs are not 1.3" drop. i had them on my car and it was closer to 2"+.
    GR2s lasted a long time on my car as well, but i didnt care about ride quality as much as others since it was a lowered car and i was expecting it to suck.
  4. #4 Re: AGX vs GR-2
    Nov 2008
    Chicago
    Fine Eibach lies. The question still remains:
    If I where to get the GR-2's 2" shorter than stock, would they still wear out prematurely?
  5. #5 Re: AGX vs GR-2
    GT Level Member GeosGP's Avatar
    Fenton, MI
    Quote Originally Posted by FuglyGTP View Post
    You will need someone who has had both. And I don't think it's necessarily the height of the shock so much as the amount of dampening required.
    2004 Grand Prix GTP Comp-G
    Stock, featuring more KR than you can shake a stick at
  6. #6 Re: AGX vs GR-2
    Jan 2009
    Tallahassee, FL
    As far as wearing out the GR-2 will wear out faster than the AGX's on lowering springs.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  7. #7 Re: AGX vs GR-2
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Im about to put AGXs on and I will let you know
    Have GR2s now and fekrin HATE THEM
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  8. #8 Re: AGX vs GR-2
    Nov 2008
    Chicago
    I ended up putting AGX's with eibach's on all four corners and I love them! It's a comfortable ride on the lowest setting IMO.
  9. #9 Re: AGX vs GR-2
    SE Level Member Bunique7's Avatar
    Feb 2009
    Des Moines, IA
    I have agx and elibach springs, I love the ride, a little rough but you are lower a car almost two inches. I had a friend with the gr-2 and elibach spring, and he perfered my set up.
  10. #10 Re: AGX vs GR-2
    Norristown, PA
    I say do it right the first time. AGX > GR2
  11. #11 Re: AGX vs GR-2
    HUDSON
    I ahve the GR-2's in the front and they ride great, and do an excellent job of dampening out the bumps. It dont really have anything to compare too, except my old front ones wich were orginall 135,000 mile ones. I guess if I wanted a softer ride, I would get a Bonneville.
  12. #12 Re: AGX vs GR-2
    Nov 2008
    Chicago
    Do you have drop springs with those GR-2's?
  13. #13 Re: AGX vs GR-2
    Houston/Baton Rouge
    I finally got my AGX and I will be installing them this weekend.
    I running B+G springs right now.
  14. #14 Re: AGX vs GR-2
    Ask Vinnie he had AGX/Eibachs but their getting shipped to me.
  15. #15 Re: AGX vs GR-2
    GT Level Member 7801MonteMan's Avatar
    S.E Michigan
    Quote Originally Posted by Ridin ON Chrome View Post
    Any updates yet on the ride?
    ASE Certified and I-Car Auto Refinishing Paint Technician
    -78 Monte Carlo -01 Monte Carlo LSX
  16. #16 Re: AGX vs GR-2
    Nov 2009
    Grand haven
    I have the Eibach springs with the gr-2's and have about 10k on my set up and NO problems at all. I live in MI where the pot holes can swallow a small car. The ride is not bad but it is much stiffer than stock. If you have the cash just get coil overs. Bio can point you in the right direction if you so desire. It just depends on how you want your car to sit.
  17. #17 Re: AGX vs GR-2
    S.E Michigan
    Yeah I know pretty much the direction that I am going in. I just wanted to know the difference between the two struts, same lowering springs and same car from a person that has seen both sides of the fence.
  18. #18 Re: AGX vs GR-2
    Donating User Odi's Avatar
    Chicago South Suburbs
    get agx. they are the better strut.
  19. #19 Re: AGX vs GR-2
    Houston/Baton Rouge
    Quote Originally Posted by 7801MonteMan View Post
    Sorry about that man. It rides great man.. I need a alignment, so its kinda weird taking corner fast, but its a lot smoother and changing the mounts out helped too.
