Thread: back brake piston stuck
Results 1 to 7 of 7
  1. #1 back brake piston stuck
    SE Level Member Lionel's Avatar
    Moncton N.B.
    I need help!
    I'm replacing my back brakes, I'm on the drivers side rear I got the old brakes off and the new ones on but i cant get the piston back in the caliper. I'm using a large c clamp and i gave it everything i got, I even used a breaker bar for more power and all it did was bend the little bar on the c clamp.
    So i thought my piston was seized so i lightly pressed the brakes and it moved.... (big mistake cuz now i cant get my old brakes back in. Is there something I'm doing wrong? is there something i need to do with the E brake or something? any help would be great my DD is sitting in the driveway useless...
  2. #2 Re: back brake piston stuck
    did you take the cap off the brake fuild container on the master cylinder.
  3. #3 Re: back brake piston stuck
    Moncton N.B.
    yes and i borrowd a huge C clamp and i still cant get the piston back in.
  4. #4 Re: back brake piston stuck
    swift current,sask.
    take and bleed some fluid off of the caliper and try and push it back in.
  5. #5 Re: back brake piston stuck
    Banned - Busted For Scamming
    Feb 2009
    What year is your car? If its 04+ it has the integral parking brake and you need a tool to twist the piston back in.
  6. #6 Re: back brake piston stuck
    Moncton N.B.
    yeah its a 2004, i figured it out... i took the caliper completely off, brought it in the house and used the c clamp again... as the c clamp was spinning, so did the piston and as it spun it went back in, then i figured out that it turns in and out as opposed to it pushing back in...
    what i dont understand is the front pushes in why doesnt the back... the passenger side took me 5 minutes with a pair of channel locks.
    oh well, it'll be easier next time thanks guys
  7. #7 Re: back brake piston stuck
    Feb 2009
    I told you, its the design of the caliper. The rear caliper's pistons has an integral ball screw mechanism that is part of the parking brake.
  1. Busted piston!!!!
    By lambokit in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2013, 11:10 AM
  2. Parking Brake Stuck
    By E90 87SS GTP in forum General Tech Discussion
    Last Post: 10-04-2009, 09:16 PM
  3. '04 rear caliper piston
    By 04GT2 in forum Brakes/Suspension/Chassis
    Last Post: 07-22-2009, 12:26 PM
  4. Piston + Valve = No Bueno
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2009, 12:12 PM
