Thread: 2000 trans am rotors on 99 GP ?
Results 1 to 19 of 19
  1. #1 2000 trans am rotors on 99 GP ?
    SE Level Member Cbierniat24's Avatar
    Mi
    my buddy is selling his drilled and slotted rotors along with his alipers... I was wondering if the rotors would fit my gp or would the bolt pattern would throw it off? Feedback is appreciated
  2. #2 Re: 2000 trans am rotors on 99 GP ?
    Jul 2008
    sumter,south carolina
    yes they will fit.. buy the calipers too and do a complete brake swap...if u dont get calipers... u will need at least mounting brackets from a firebird or monte carlo.
    02 GTP with mods 05 GP for DD
  3. #3 Re: 2000 trans am rotors on 99 GP ?
    Mi
    alright thankss!! Does this work with the back brakes as well?
  4. #4 Re: 2000 trans am rotors on 99 GP ?
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by Cbierniat24 View Post
    no
    You need the calipers, brackets, rotors and pads.
    and you either have to drill and tap the bracket holes to accept the GP bolt or use the sleeve method.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  5. #5 Re: 2000 trans am rotors on 99 GP ?
    Mi
    why couldnt i just use the f-body banjos?
  6. #6 Re: 2000 trans am rotors on 99 GP ?
    Mi
    I take that last question back. I thought about it for a min and realized.
  7. #7 Re: 2000 trans am rotors on 99 GP ?
    Donating Users
    South Deerfield, MA
    The bolt pattern on a Trans Am is different than on a Grand Prix. You might want to double check to see if it will fit. Hold one of the rotors up to one of your wheels and see if the lugnuts will line up with the holes in the rotor.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  8. #8 Re: 2000 trans am rotors on 99 GP ?
    Quote Originally Posted by Silver GTP View Post
    The fronts fit for sure...
  9. #9 Re: 2000 trans am rotors on 99 GP ?
    Donating Users
    South Deerfield, MA
    Not trying to argue, just asking since I don't understand, but how does a different bolt pattern fit over our hub? Are the holes ovalled to fit different bolt patterns or do the F-body rotors have two different sets of holes to fit different bolt patterns?
  10. #10 Re: 2000 trans am rotors on 99 GP ?
    They're the exact same bolt pattern.
    Thats an issue you're making up.
  11. #11 Re: 2000 trans am rotors on 99 GP ?
    Mi
    That's what Im trying to figure out but I am getting different answers. I will be trying it out and will let you know asap.
  12. #12 Re: 2000 trans am rotors on 99 GP ?
    Holy **** balls, they're different.
    They're 5x 120.7
    This makes no sense now.
    GP's are 5 x 115. But ever notice how much play there is around the lugs with the holes in your rotors?
  13. #13 Re: 2000 trans am rotors on 99 GP ?
    Donating Users
    South Deerfield, MA
    Apology accepted. I try not to talk out my *** and look things up if possible. There is play around the holes but I don't know if they will make up that much difference. What is the diameter of the hole for the hub? Most rotors fit snug on the hub to hold them centered and this could be an issue as well.
  14. #14 Re: 2000 trans am rotors on 99 GP ?
    im fairly certain that the impala uses the same rotors as the F body's yet has the same bolt pattern as the GP as well as the same hub size.
  15. #15 Re: 2000 trans am rotors on 99 GP ?
    Donating Users
    South Deerfield, MA
    Apparently internet forums are not the only places to find disagreements on this subject. I went to rockauto and looked up rotors for both the Trans Am and the Grand Prix and looked at the drawings provided by Centric for the rotors on both of these cars. They match every spec except outer diameter. However, they show both rotors having a 5 x 4.65" bolt pattern which would be about 5 x 118mm. Maybe your idea about the holes being a little larger to accomodate two different sizes is dead on? Anybody have first hand experience trying to fit F-body rotors onto a GP?
  16. #16 Re: 2000 trans am rotors on 99 GP ?
    Jul 2008
    yea i feel kinda stupid... i always thought they were exact same as newer monte carlo with the 11.9 rotors... google says its not....
  17. #17 Re: 2000 trans am rotors on 99 GP ?
    the holes are a lot larger so they can go on a bunch different cars. put the rotors on and play with them a little to see what we mean. they have a ton of play.
  18. #18 Re: 2000 trans am rotors on 99 GP ?
    Jul 2008
    this makes sense... i was under teh impression i had F body rotors on car when i bought it... they have alot of play in them but have worked fine up until now. the powerslots i just bought and havent installed yet looks like the holes are smaller. and i bought for 2005 monte
  19. #19 Re: 2000 trans am rotors on 99 GP ?
    Houston/Baton Rouge
    F-body rotors and the 00-05 impala/monte 12" rotors are the exact same. Same part number and everything.
    The holes are drilled with a lot less tolerance then the wheels.
  1. m90 Rotors
    By Lion29GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2010, 10:27 PM
  2. Trans type in 2000 malibu?
    By Liquifire in forum General Tech Discussion
    Last Post: 08-10-2009, 10:34 PM
