Thread: Tire rubs in turn-Bent control arm?
Results 1 to 9 of 9
  1. #1 Re: Tire rubs in turn-Bent control arm?
    Donating Users shawn's Avatar
    rogers arkansas
    I'm havn same knda issue too.. No rubbing but my right side has lil less of a gap than driver side...never been wrecked and not as bad as yours but really noticeable.. Can that jus b normal wear and tear ?? Mayb jus new cntrol arms will fix this problem ?
    STOLEN XPZ SETUP WITH CNC PORTED HEADS!!
    13.76@99.60 on 3.4 setup
  2. #2 Re: Tire rubs in turn-Bent control arm?
    Spokane, WA
    I guess the tiniest amount of the wrong angle on the inboard side can make a significant difference out at the outboard part where tire makes its arc turning. I'll definitely get one on order and find a good how-to thread for swapping a control arm. I don't think I've ever repaced that part.
  3. #3 Re: Tire rubs in turn-Bent control arm?
    Donating Users
    South Deerfield, MA
    Real simple to change. Jack up both sides of the front end. Remove the abs wire from the clips on the control arm. Remove the sway bar end link (will probably need a new one). Take the nut off the ball joint (18mm iirc). Take the two bolts out of the control arm (18mm, 21mm and T-55 iirc). Remove and reinstall the new one. Make sure you torque the two bolts that tie into the cradle while the suspension is at ride height. Done. I can look up torque specs if you need them.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  1. Dont like to turn left but easy to turn right
    By Randall in forum General Tech Discussion
    Last Post: 02-01-2013, 12:11 PM
  2. What would bent dog bones cause???
    By FlaminWhite97GTP in forum Brakes/Suspension/Chassis
    Last Post: 02-15-2010, 07:43 PM
  3. Tire Pressure light wont turn off.
    By Fivefingerdeathpunch in forum Introductions/Noob Questions
    Last Post: 09-25-2009, 10:40 AM
  4. Bent rims
    By rocafella2032 in forum The Rant Forum
    Last Post: 06-20-2009, 12:31 AM
  5. rear O2 for U bent delete
    By SofaKingCdn in forum General Tech Discussion
    Last Post: 10-04-2008, 08:59 PM
