Thread: brake parts to get for brake upgrade??
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 brake parts to get for brake upgrade??
    GTX Level Member colindunn's Avatar
    Aurora, IL
    I plan on ordering all my parts from rock auto. for my front im going with the upgraded monte carlo ss brakes. i also order the caliper brackets for the monte carlo also right? along with the rotors. then for the rear im going with just the stock rotors. is this all good?
  2. #2 Re: brake parts to get for brake upgrade??
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Yes, you need the caliper, brackets, pads and rotors.
    for the rear. Stock rotors and pads.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  3. #3 Re: brake parts to get for brake upgrade??
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    order the hardware kit with the brackets or they will vibrate and clunk when you hit bumps
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  4. #4 Re: brake parts to get for brake upgrade??
    Donating Users
    South Deerfield, MA
    You do not need calipers. Order pads for your car and the caliper brackets and rotors from the Monte. As stated, you will also need the hardware kit to get the rubber boots that cover the caliper slide pins. I just did this a little over a month ago and it is a nice upgrade.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  5. #5 Re: brake parts to get for brake upgrade??
    MA
    Quote Originally Posted by Silver GTP View Post
    how much did that run you, if you dont mind me asking
    SMGPFC Member #9
  6. #6 Re: brake parts to get for brake upgrade??
    Donating Users
    South Deerfield, MA
    Brackets run about $50 shipped with the hardware kit. Pads and rotors depend on the quality you buy.
  7. #7 Re: brake parts to get for brake upgrade??
    depending on how much you want to spend ls1tech.com in the ls4 section has a few guys doing Z06 and 2010 camaro brembo brake swaps! Most likely more than you wanted to spend just throwing that out their because people thought I was crazy a while ago saying CTS-V brake swap would be sweet. BTW the CTS-V and 2010 camaro brakes are the same from what Ive heard anyway. Also their is a guy that just put some cadillac DTS calipers brackets and rotors on his car. Cant remember if it was a monte or what though. Its all on ls1tech.com The DTS swap sounds pretty cost effective. Also the impalas have smaller brake boosters for a firmer pedal feel. Lol Im kind of a forum troll. ls1tech.com has all kinds of cool stuff on their.
  8. #8 Re: brake parts to get for brake upgrade??
    Aurora, IL
    Quote Originally Posted by 02GrandPrixIraqVet View Post
    yeah im on a budget but that would be cool. Im just doing the cheapest upgrade that will give me a little more performance out of them.
  9. #9 Re: brake parts to get for brake upgrade??
    Houston/Baton Rouge
    not unless he wants to get the 06+ monte/impala which are dual piston and way better then the stock calipers.
    Thats what I thought he was talking about.
    Screw using stock calipers and 12" brackets..
    You can get 06+ monte/impala calipers and brackets for around the same price as those 12" old monte brackets.
  10. #10 Re: brake parts to get for brake upgrade??
    Houston/Baton Rouge
    That guy hasent even bolted the camaro calipers. Just set them on the rotors. He doesnt even know if they will work yet.. So I wouldnt even try and attempt that.
    Not only that, you need atleast 20s to run the 14" camaro brakes.
    The CTS and DTS calipers are doable. There the same as the GXP,but you need at least 17s to run them.
  11. #11 Re: brake parts to get for brake upgrade??
    Aurora, IL
    Quote Originally Posted by Ridin ON Chrome View Post
    i actually did not know that. so i could do an 06+ upgrade? what all would i need? the rotors for an 06 monte are 55 bucks a piece. not looking to spend that much. or could i use different rotors.
  12. #12 Re: brake parts to get for brake upgrade??
    Houston/Baton Rouge
    Quote Originally Posted by colindunn View Post
    You need the caliper/brackets, rotors, pads.
    Bolts up like stock, just have to bend the brake line a little to get to the bleeder valve.
    $110 on rotors is pretty cheap. No offesne, but brakes are important and wouldnt cheap out.
    Its been a while since I looked, but im pretty sure the 12" rotors from the old monte are not much less.
  13. #13 Re: brake parts to get for brake upgrade??
    Aurora, IL
    the old monte are around 30 a piece. and i also wouldnt have to buy new calipers which are also expensive. but il defiantly consider it.
  14. #14 Re: brake parts to get for brake upgrade??
    Houston/Baton Rouge
    I understand.
    You can buy used low millage impala calipers and brackets for around $50 for left and right.
  15. #15 Re: brake parts to get for brake upgrade??
    You mean to tell my you need 20 inch wheels for a 14inch rotor? How do you figure? Thats about 6 inches of caliper clearance which is far more than needed. The thread I was talking about also has a set of Z06 calipers behind GXP wheels sure looks like it will fit to me.Z06 front brake conversion on GXP - Page 6 - LS1TECH Also the cts-v uses 14 inch rotors on 18inch wheels factory. Im about 99% sure the cts-v and 2010 brakes are the same.
  16. #16 Re: brake parts to get for brake upgrade??
    CT
    From my understanding you don't NEED to get new calipers. You need the brackets, rotors, and pads along with the sleeves for the bracket and correct bolt. This would give you more pad contact patch on the rotor which would increase your stopping power. Adding on the dual piston calipers and even larger brake pads provides even more stopping power. If your on a budget I'd honestly just go with stock for right now and save up to get a nice set of 12" dual piston calipers and parts for the upgrade. Then you can paint them and do other such things to make it a nice clean upgrade.
  17. #17 Re: brake parts to get for brake upgrade??
    Houston/Baton Rouge
    Go look it up, I think 19s barley fit on camaros and most say 18s might fit if you find the right ones. I said 20s so you for sure would have problems. Do wonder why the camaro doesnt have 19s stock?
    and who cares about the GXP wheels and Z06 brakes. Im not even talking about them. I already said you need atleast 17s to run GXP brakes and dending on what size C6 rotors you use. Might need a larger rim.
    and depending on what gen CTS-V your talking about. The old ones run 18s, but dont have 14" brembos.
    The new ones run 19s and 14" brembos. So do your homework next time.
    http://blog.cochesalaventa.com/_foto...2_31753_20.jpg
  18. #18 Re: brake parts to get for brake upgrade??
    Houston/Baton Rouge
    Quote Originally Posted by dagger View Post
    You are talking about F-body calipers...
    Totally different. Im talking about 06+ impala/monte calipers. They bolt on like stock. No sleeves.
  19. #19 Re: brake parts to get for brake upgrade??
    Homework for you. Apparently according to you wiki is wrong?
    The first generation CTS-V is based on the same GM Sigma platform as the base model CTS. The use of a V8 engine required a unique engine cradle distinct from the base CTS V6. Larger anti-roll bars and larger shocks were also added. The spring rate was significantly increased. The 2006-2007 update also included a stronger rear differential and half shaft design. Unique front and rear treatments also included mesh grilles over the front openings, a track-ready suspension, and 18x8.5 inch wheels inside of P245/45R18 Z-rated Goodyear Eagle F1 Supercar run-flat tires. Brakes were 14.0-inch (360 mm) rotors with four-piston Brembo calipers at each wheel. In addition, GM badges were added on 2006 models.
    Ohh so do your home work next time.
  20. #20 Re: brake parts to get for brake upgrade??
    Read this post Ridin ON Chrome. brembo part #... [Archive] - Cadillac Owners Group
    These calipers are on a few different cars. Different color Different part # other wise same caliper.
    Homeworks done my friend me 2 points you 0
  1. Brake upgrade
    By rocket69GTP in forum Brakes/Suspension/Chassis
    Last Post: 04-17-2010, 12:35 PM
  2. Brake Upgrade
    By bct717 in forum Brakes/Suspension/Chassis
    Last Post: 05-01-2009, 10:21 PM
  3. fbody brake upgrade
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2008, 09:59 AM
  4. 05 brake upgrade?????
    By duane9586 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2008, 02:47 PM
