Im wondering if 97-03 lowering springs work with the newer cars?
Thanks
so i emailed vogtland direct, and they said that the springs are made car specific and they wont fit..... That kind of sucks lol. Still going to email a few more places
Edit: W-Body store says the springs work, excluding the GXP. So im going to go ahead and order them anyways
So, here's a question. If you put 97-03 struts on your 04+ car, do you put on 97-03 springs or 04+ springs? The struts are essentially the same except for that front sway bar mounting point, so the only difference I could see is if there's something to do with the weight of the car and/or the weight disbursement for those springs.
i'm curious how accurate this is. someone just posted up a set of Eibach PRO-KIT Performance Springs for 50 bucks locally.
They do fit, but the rear ones will drop more. Since the 04+ springs are a little longer in the back.
