Thread: Brake upgrade
Results 1 to 20 of 22
  1. #1 Brake upgrade
    May 2008
    Just wanted to ask if anyone has pictures of the brake upgrades they have done to their cars, specifically NOT LS1 or GXP upgrades. Looking along the lines of brembos, baer, or even wilwoods, thanks.
  2. #2 Re: Brake upgrade
    But those are expensive... And do the same thing as say a rear GXP and front C5 caliper setup.
  3. #3 Re: Brake upgrade
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    there's only like 2 people with baer brakes. Both on clubGP.
    dont think anybody has brembos or wilwoods or the SSBC
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  4. #4 Re: Brake upgrade
  5. #5 Re: Brake upgrade
    Fort Atkinson
    they are so expensive an unnecessary...
    I beg to differ.
  6. #6 Re: Brake upgrade
    with fbody brakes, or even the GM 12" upgrade, the car stops just fine. to spend $1000+ on brakes is idiotic.
  7. #7 Re: Brake upgrade
    May 2008
    The only reason I was asking is because I seen a guy with a Monte Carlo SS that was able to bolt up the new 4 piston brembos used on the 2010 Camaro. I was trying to determine if they use the same spindles that are used on the Grand Prix GXP and in turn, used on our cars. From the research I have been doing, the calipers are relatively inexpensive and would be no more than about $500 for the upgrade.
  8. #8 Re: Brake upgrade
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    That's more realistic than a big brake kit. Big brake kit is more or less a bling thing unless your track racing the piss out of your grand prix which most ppl don't do. Just do what everyone else do except since most gps come with a spongy brake pedal feel as well upgrade to stainless lines your car will like you for it.
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  9. #9 Re: Brake upgrade
    May 2008
    I have the GXP front brake swap all ready so I will go with that and see what happens. I drive through the mountains on a regular basis and the brakes heat up pretty quick.
  10. #10 Re: Brake upgrade
    Fort Atkinson
    so autox and track racers are idiots? everyone mods there cars to go like hell,but no one ever thinks about making them stop better.
  11. #11 Re: Brake upgrade
    Houston/Baton Rouge
    Quote Originally Posted by rocket69GTP View Post
    where, info? pics, links?
    those a 14" rotors on the new camaro SS..
    the monte SS is a w-body and has the same stuff we have. He much have used a custom bracket...
  12. #12 Re: Brake upgrade
    May 2008
    Z06 front brake conversion on GXP - Page 4 - LS1TECH
    I am still waiting for him to post up the finished product but you get the idea.
  13. #13 Re: Brake upgrade
    Quote Originally Posted by Thinkmoto View Post
    even for the occaisional auto-x outing i think they are a waste. if you need them for auto-x'ing your gp then go for it, but if youre mainly using your car on the street then its a giant waste. its also a waste to have drilled/slotted rotors on the street, but yeah.
  14. #14 Re: Brake upgrade
    Houston/Baton Rouge
    interesting.. Looks nice
    I could seem them working, but I know for sure he's going to need a custom bracket and like he said brake lines might not work.
  15. #15 Re: Brake upgrade
    Fort Atkinson
    drilled/slotted on the street LOL, sorry I'm not ricer joe so no for me on those.
  16. #16 Re: Brake upgrade
    Drilled rotors help with ridding of heat but guess what helps even more... ducts that deliver cold air to the rotors. I posted a link a while ago to a mini cooper forum where they would take out their fog lights then run piping to the rotor from the back of the foglight opening. THAT seemed to enable them to be able to autocross their mini's with stock brakes more-so than anything else.
    Personally for the the street, try better pads, then the 12" rotors then LS1/ C5 calipers. (preferably C5's since they're smaller in piston displacement hence better brake feel), smaller brake booster (from the impala) and then maybe venting your brakes as mentioned above.
    Just get some raybestos or centric rotors since they wont rust and are US made so they shouldn't warp.
    When people think they have warping, they should try rebedding their pads first before getting new rotors or getting them turned... most of the time its just you exceeding the heat range of your pads.
  17. #17 Re: Brake upgrade
    Kansas
    any recommendations on pads? My brakes are squeaking like a ***** lately and i got all new pads and rotors 6 months ago.
    SOLD 1999 GT Silvermist TS
  18. #18 Re: Brake upgrade
    Nov 2009
    Portage, IN
    So the c5 will bolt up to what bracket? Because I will just run those if this is the case.
  19. #19 Re: Brake upgrade
    Houston/Baton Rouge
    Quote Originally Posted by Gafford44 View Post
    I like wagner thermo quiets
    Quote Originally Posted by ls6velless454 View Post
    C5 brackets with work or f-body. Doesnt matter
  20. #20 Re: Brake upgrade
    I remember a while ago I posted a thread about CTS-V brakes see them on a camaro made me think they should fit a Grand Prix and people thought I was nuts.
  1. Fbody/C5 Brake Upgrade Help
    By arc in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2010, 12:05 AM
  2. Brake Upgrade
    By bct717 in forum Brakes/Suspension/Chassis
    Last Post: 05-01-2009, 10:21 PM
  3. fbody brake upgrade
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2008, 09:59 AM
  4. 05 brake upgrade?????
    By duane9586 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2008, 02:47 PM
