Thread: Front to rear brake line replacement - need advice
Results 1 to 5 of 5
  1. #1 Front to rear brake line replacement - need advice
    OH
    Hey group,
    Never done this one before, and actually have never had to have it replaced before.
    Is it hard to do? Mechanic is quoting me (over the phone, hasn't seen the car yet) around $650, because once one line goes the rest are sure to follow?
    How long do you think it'd take a first-timer to get it all done?
  2. #2 Re: Front to rear brake line replacement - need advice
    Niagara
    Its not that hard, just get some lines, a bender,and a DOUBLE flaring tool, and give it a shot. It would be a good idea to practice double flaring on some scrap first. (and dont forget to put your fittings on BEFORE you flare the ends.
  3. #3 Re: Front to rear brake line replacement - need advice
    our cars have 3/16's line right?
    Also anyone know the fitting size?
  4. #4 Re: Front to rear brake line replacement - need advice
    OH
    I took my old line off and took it to the auto parts store. I had different fittings on both ends and a bubble flare! News to me :-D But my car used to be part of a rental fleet, so maybe that's why that happened?
    Good luck & make sure you buy the coated kind - I did! No more rust for me I hope!
  5. #5 Re: Front to rear brake line replacement - need advice
    Quote Originally Posted by bxfl View Post
    Thats definately f*cked up. sounds plausible to me.
    Parents acura... 01, near 200 K miles, rust on the body, non rusty brake lines. Coating + changing brake fluid helps quite a bit.
  1. Fluid cooline line replacement issue
    By Sabrewings in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-05-2013, 11:50 AM
  2. Fbody brake line question
    By minichopper6hp in forum Brakes/Suspension/Chassis
    Last Post: 05-09-2009, 05:00 PM
  3. ZZP's 5th Stainless Brake Line!!
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-17-2008, 06:06 PM
  4. brake line fitting ?
    By quiksilvergt in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 06:42 PM
  5. Parts are in for fuel line replacement
    By BlackGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2008, 10:00 AM
