Thread: Want to lower your car? Look in here!!
Page 18 of 29 FirstFirst ... 8161718192028 ... LastLast
Results 341 to 360 of 575
  1. #341 Re: Want to lower your car? Look in here!!
    North Jersey
    bullits.
    with a 245/45/r17 tire.
  2. #342 Re: Want to lower your car? Look in here!!
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    did you roll them?
    97 gtp- 3.5 pulley, sd headers, autolite 104's, dhp pcm, hai, 180 t-stat SOLD
    94 skyline- drift slut SOLD
    97 rx7 fd3s twin turbo SOLD
    99 R34 skyline
  3. #343 Re: Want to lower your car? Look in here!!
    North Jersey
    need to.
    don't know how.
    if its something i could do myself, or do i need a shop to it...
  4. #344 Re: Want to lower your car? Look in here!!
    Quote Originally Posted by Oxfire View Post
    Does anyone know off hand which are the "shortest" struts?
    Dave looked into this, none.
    They're all stock length.
    You'll have to call koni or bilstein and ask them to make you shorter ones.
  5. #345 Re: Want to lower your car? Look in here!!
    Jan 2012
    Philadelphia
    alright guys i know this might be a stupid question but i dont know, how do anti-pogo washers work?
    i have ebiach springs with gabriel ultra struts (not installed yet) i bought these struts because there lifetime warranty so i figured when the springs where out the struts i can always get new ones
  6. #346 Re: Want to lower your car? Look in here!!
    I think Monroe's website was eff'd, claiming nothing was short, seemed odd. No one will give me their numbers.
    I'm thinking about trying to find another car that has coilovers that will fit the fronts. I'm going to look into the Maxima's
  7. #347 Re: Want to lower your car? Look in here!!
    Quote Originally Posted by jerZcavy4120 View Post
    ok. its official.
    i need to do something about my rear fenders.
    i'm tired of rubbing on EVERYTHING.
    help?
    take your rear wheels off. using a heat gun, heat up the lip on the fenders until they are HOT to the touch.
    use a rubber mallet and bend the lip of the fender up, slowly working your way around so it all goes up at the same time. KEEP IT HOT.
    that's seriously all there is to it. that's how i've done all mine. the roller is just 'cleaner', but the hammer method will yield a flatter roll without pulling the fender.
    GT Level Member iRideGTP's Avatar
    Jul 2012
    California
    Quote Originally Posted by gtpeddie View Post
    How this mod works: The top strut mount on the front fenders have a retaining nut along with a retainer cap; this will hold the strut rod, which comes through the center of the mount, in place. With the stock springs, this retainer is in direct contact against a rubber cushion underneath it, this is what directly connects the strut to the mount. With lowering springs, this retaining cap is raised up about a quarter to a half inch, so the strut is no longer firmly secured against the mount! What this means is that the spring can bounce up and down this tiny bit before the strut even begins to act on it.
    http://www.clubgp.com/cgi-asp/mods.asp?modid=68
    Sent from my SGH-T679 using Tapatalk 2
  9. #349 Re: Want to lower your car? Look in here!!
    Jan 2012
    Philadelphia
    thanks!
  10. #350 Re: Want to lower your car? Look in here!!
    Sep 2012
    illinois
    how hard is it to install a lowering kit?
  11. #351 Re: Want to lower your car? Look in here!!
    Jan 2012
    Philadelphia
    i dont think its that hard you just need to use a spring compressor then take apart your struts and put the new lowering springs in
  12. #352 Re: Want to lower your car? Look in here!!
    Sep 2011
    Vancouver
    i did my front ones in 15minutes and rear in half an hour. was my first time doing that job too. air tools help
    99 R34 skyline
  13. #353 Re: Want to lower your car? Look in here!!
    Jan 2012
    Philadelphia
    should i run shorter dog bones with my ebiachs?
    Nope. Run vinnie spacers instead...check out the community vendors and sell me your eibachs
    Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
    04 Comp G.
  15. #355 Re: Want to lower your car? Look in here!!
    Jan 2012
    Philadelphia
    if i ever get rid of them you can have dibs lol
  16. #356 Re: Want to lower your car? Look in here!!
    Jan 2012
    Philadelphia
    well i cant run them i dont think because im already gonna have problems with hood clearance and my S2IC
    Cradle spacers to help with the height of the SSIC...Zzp sells them. And you wont able to use those shorter dogbones with those fancy headers you acquired.
    04 Comp G.
  18. #358 Re: Want to lower your car? Look in here!!
    Jan 2012
    Philadelphia
    Cradle spacers to help with the height of the S2IC...Zzp sells them. And you wont able to use those shorter dogbones with those fancy headers you acquired.
    fixed lol and i was planning on getting them, i didnt know you couldnt use shorter dog bones with pacesetters
    Excuss me fancy pants lol. Yup shorter dogbones are for stock manifolds...any set of headers wont allow short DB. If all else fails with the Vinnie Spacers you dont have to run the full set. You can run a half set if your having clearance issues.
    04 Comp G.
  20. #360 Re: Want to lower your car? Look in here!!
    Jan 2012
    Philadelphia
    thanks i didnt know that, id have to look into it more the only reason i have clearance issues is because of that damn SD hood
  1. About the Lower intake & S/C
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2009, 03:39 PM
  2. rear end lower
    By 52 picup in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:54 AM
  3. how to lower?
    By 89prix in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2008, 07:17 AM
  4. Lower
    By 98GPGT in forum Brakes/Suspension/Chassis
    Last Post: 10-14-2008, 07:45 PM
  5. Lower KR ?
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2008, 09:04 PM
