basically. unless you don't want to lower your car.
i knew the eibachs were progressive not linear. I really know nothing about valving and jazz. ive been trying to learn it all but it seems to be one of those things ill understand once i do it
Hey guys I've been looking thru the forum and I didn't see a spring that can take the car down about 2" or a little more and have a good load rate... Anyone got any ideas???
SSC's will only go maybe 1.5in, and that will take many miles for the springs to settle.
Your better off with a different spring or coilovers.
Eibach's and AGX. Yuss or nao?
Yes. Will make for good times.
Side note, my SSC's dropped me a little over 2" and ride pretty decent. Obviously the ride isn't stock, but it's not too shabby.
I figure- $150 for AGX's. $250 for Springs, and under $20 for antipogo warshers. I've never seen coilovers nearly that cheap
You may want to do some research the agx blow out quick when lowered. The cheaper gr2 seem to hold up slot better and are ***cheaper**
So $850...then they blow out and your out if money.
Or maybe what $250 ish for gr2.
Or my option
Make your own coilovers and save moolah
All of you guys got good ideas. This is not my first time dropping my car I kind of did it a cheap way and now I have to go back thru and redo everything. And also the gr2 are $203 from kyb web Page....
coilovers run about 175-200 for everything per axle so just add that to the strut price. if you wana pay for helds or something like that than youll have to pay to play on that
