Thread: Want to lower your car? Look in here!!
Page 27 of 29 FirstFirst ... 172526272829 LastLast
Results 521 to 540 of 575
  1. #521 Re: Want to lower your car? Look in here!!
    Donating User Odi's Avatar
    Chicago South Suburbs
    Quote Originally Posted by 91parkave View Post
    No spacers no vibrations on my coilovered Gxp my 97 gtp with SSC never had those vibrations either.
    Still doesn't change the fact that the axle geometry is affected.
  2. #522 Re: Want to lower your car? Look in here!!
    Arizona
    if you're axles point upwards then you have issues an geometry is affected. My axles are level.
  3. #523 Re: Want to lower your car? Look in here!!
    Not talking about the GXP
  4. #524 Re: Want to lower your car? Look in here!!
    Arizona
    It doesn't matter Gxp gtp gt all wbody suspension has the same problem if you slam them. I'm referring to my gtp in the previous post btw.
  5. #525 Re: Want to lower your car? Look in here!!
    good for you.
  6. #526 Re: Want to lower your car? Look in here!!
    Jul 2013
    Antioch, CA
    If I may ask, what year was this GTP and what was the setup? If I can get away from modding everything just to get it a little closer to the ground I would prefer that. I'm not trying to slam it like some silly ricer, I just want to get a better center of gravity for cornering.
  7. #527 Re: Want to lower your car? Look in here!!
    Oct 2011
    Toledo, OH
    This.
    Also, depending on your mileage, your motor/tranny mounts could be quite a bit worn by now making the geometry even worse. The pair of solid mounts are like $40 shipped, why not just get the spacers and replace the mounts at the same time.
    7"
  8. #528 Re: Want to lower your car? Look in here!!
    GT Level Member MCbatt's Avatar
    Oct 2013
    MARYLAND
    When I lowered my car I had a little vibration at first, about the first week or so. I decided to change the trans and motor mounts and the vibration completely went away. It feels like it did before I lowered it when accelerating now. Definitely do your mounts when you lower.
    Courage is fear hanging on a moment longer.
    -Thomas Fuller-
  9. #529 Re: Want to lower your car? Look in here!!
    Nov 2012
    Madison
    Quote Originally Posted by industrialfish View Post
    This.
    Quote Originally Posted by MCbatt View Post
    True....
    I did spacers but being on a budget at the time I just did spacers.
    The mounts looked OK but being real after close to 100k....come on.
    The spacers got rid of the wobble and quite possibly mounts might have done the same thing.
    Most def the ideal solution would be for mounts and spacers for the 100% solution.
    Now, the next order is mounts. This thread saves the day and helps me spend money wisely
  10. #530 Re: Want to lower your car? Look in here!!
    No acceleration vibration ? I call bs
    Sent from my Nexus 4
    No vibration at all anytime.
  11. #531 Re: Want to lower your car? Look in here!!
    Arizona
    good for you.
    What are you 4? Grow Up
    Quote Originally Posted by Grindal View Post
    97, like I said already though most vibration happens when people don't take care of other things first. If you have motor mounts and axles with 100k on them...expect that when you lower your car you will have issues.
  12. #532 Re: Want to lower your car? Look in here!!
    You're on fresh mounts, fresh axles. Sure you won't feel vibrations, yet. But the geometry already changed its a transversely mounted engine. If you're happy without spacers good for you, but the proper way of lowering is with engine and tranny spacers.
  13. #533 Re: Want to lower your car? Look in here!!
    Jul 2013
    Antioch, CA
    Mine has about 135k on it, so new motor/trans mounts just make sense. I am replacing 90% of the suspension when I drop it, new springs, struts, mounts and rubber on all 4 corners. The only parts I'm reusing are the nuts on the top that hold the strut to the springs and one of the two bolts that hold each strut to the LCA. Got the MOOG adjustable +1.5 ~ -1.5 alignment bolts for each wheel so I don't have any surprises. I don't know about the rears, but I know the front upper strut mounts are shot, so they are all going. Also adding the strut tower braces from Summit. After I get the larger front sway bar and add one to the rear, should have a really solid feeling GTP.
  14. #534 Re: Want to lower your car? Look in here!!
    Skip the braces, save yourself the money.
    You'd notice zero difference because you are already lowering the vehicle and adding better sway bars and links.
  15. #535 Re: Want to lower your car? Look in here!!
    Pretty much. I'm using speedbuilt stb's and the difference is negligible.
  16. #536 Re: Want to lower your car? Look in here!!
    Jul 2013
    Antioch, CA
    I plan to race this car, have some friends that do autocross, the braces help keep the suspension geometry when I'm whipping it like a red headed step child. I've heard it said it's better to over support it, I'm more erring on the side of caution. The strut tower braces are only about $130 each, so it's not bad compared to everything else I'm doing.
  17. #537 Re: Want to lower your car? Look in here!!
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    ZZPs are cheaper FYI
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  18. #538 Re: Want to lower your car? Look in here!!
    Try getting proper stb's like speed built so they mount around all 3 strut bolts
  19. #539 Re: Want to lower your car? Look in here!!
    Jul 2013
    Antioch, CA
    The ones from BMR sold on Summit's website do bolt to all 3 holes, which ones were you referring to?
  20. #540 Re: Want to lower your car? Look in here!!
    GT Level Member atj8's Avatar
    Midwest
    quick question for the lowering gurus...i got a set of used/older vogtland spings...how do i know which ones go in the back and front? 2 are black 2 are red...thanks in advanced
  1. About the Lower intake & S/C
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2009, 03:39 PM
  2. rear end lower
    By 52 picup in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:54 AM
  3. how to lower?
    By 89prix in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2008, 07:17 AM
  4. Lower
    By 98GPGT in forum Brakes/Suspension/Chassis
    Last Post: 10-14-2008, 07:45 PM
  5. Lower KR ?
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2008, 09:04 PM
