Thread: Want to lower your car? Look in here!!
Page 25 of 29 FirstFirst ... 152324252627 ... LastLast
Results 481 to 500 of 575
  1. #481 Re: Want to lower your car? Look in here!!
    Sep 2013
    California
    really, since spring rates and better handling aren't exactly worked with very often with most grand prix owners, i don't think there is a consensus on what everyone considers the "right" spring rates.
    i'd like to think that 7k/6k (393/337 lb/in) f/r would be a good place to start. i know a few guys will do the 400#/350# or so f/r.
    How would I be able to find out that info on the springs....
  2. #482 Re: Want to lower your car? Look in here!!
    Sep 2013
    California
    Oh and I just got in my gr2's/excel-g
  3. #483 Re: Want to lower your car? Look in here!!
    Quote Originally Posted by Cali boi View Post
    what do you mean?
  4. #484 Re: Want to lower your car? Look in here!!
    Sep 2013
    California
    what do you mean?
    Oh sorry.. As far as the spring rate on them... Like for eibach, b&g, and a few others
  5. #485 Re: Want to lower your car? Look in here!!
    the first post in the thread has all of the information you're looking for. or the second, which is where the spring rates are.
  6. #486 Re: Want to lower your car? Look in here!!
    Sep 2013
    California
    Oh ok thanks.
  7. #487 Re: Want to lower your car? Look in here!!
    Donating Users crock's Avatar
    Traverse City, Michigan
    I have the opportunity to purchase eibachs. Are they harsh on a DD? They will have GR2s brand new and new kyb mounta with new solid mounts and spacers. What is the progressive versus linear? They say they are a 1.3 drop so why are people saying they are a two inch drop? They are a good price though. I just ha e the torque stars on there now. Thanks.
  8. #488 Re: Want to lower your car? Look in here!!
    had eibachs on my regal GS loved the drop and look of them hated the AGX struts with them that sucked balls IMO if you use GR2s I think youll be fine others can say what they want I will never use AGX struts again.
  9. #489 Re: Want to lower your car? Look in here!!
    Jan 2009
    Tallahassee, FL
    My Eibachs rode fine. Progressive just means that the spring rate changes as the spring compresses. They start out soft then get stiffer. Linear springs have the same rate no matter compression.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  10. #490 Re: Want to lower your car? Look in here!!
    So one of my strut towers has about a inch or two of rust coming through. Only rust on that vehicle. Will that get worse with the eibachs? I'm always cautious of bumps and pothole. And I'm going to sand it down and paint before I do that strut. Its really not as bad as some of these peoples towers.
  11. #491 Re: Want to lower your car? Look in here!!
    it shouldn't get worse, but while it's all apart i'd do my best to clean it up and make sure it's not a structural issue with the car.
  12. #492 Re: Want to lower your car? Look in here!!
    Sand it down and coat it? From the top its really not that bad. What would you recommend using?
  13. #493 Re: Want to lower your car? Look in here!!
    sand it down real well and use something like POR15 to completely eliminate the issue.
    otherwise if it isn't bad any old paint will do. you just want to seal it so it doesn't rust anymore.
  14. #494 Re: Want to lower your car? Look in here!!
    I'd weld a small plate/patch in that area to give it strength back and then seal it up good.
    Thats what I did on my car before lowing on SSC springs.
  15. #495 Re: Want to lower your car? Look in here!!
    GT Level Member TheDarkAngel's Avatar
    Oct 2013
    Iowa
    Where can I buy the Intrax springs?
    First car- 1999 Buick Regal LS (Sold)
    Current ride- 2000 Grand Prix GT (The Dark Angel) DIY Intake, flipped bushings, visual stuffs, lowered on Eibachs, Topswap loading...........
  16. #496 Re: Want to lower your car? Look in here!!
    Quote Originally Posted by TheDarkAngel View Post
    good luck. they're discontinued.
  17. #497 Re: Want to lower your car? Look in here!!
    Better go with c/o if you want that low or stick with Eibachs
    04 Comp G.
  18. #498 Re: Want to lower your car? Look in here!!
    SE Level Member Konvinced89's Avatar
    Layton, UT
  19. #499 Re: Want to lower your car? Look in here!!
    Dec 2010
    ATL,Georgia
    Bags!!
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  20. #500 Re: Want to lower your car? Look in here!!
    Jun 2013
    Hollywood ,FL
    Anyone still running dnas loving that rake look how do you love them
    Sent from my SGH-T999N using Tapatalk
  1. About the Lower intake & S/C
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2009, 03:39 PM
  2. rear end lower
    By 52 picup in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:54 AM
  3. how to lower?
    By 89prix in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2008, 07:17 AM
  4. Lower
    By 98GPGT in forum Brakes/Suspension/Chassis
    Last Post: 10-14-2008, 07:45 PM
  5. Lower KR ?
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2008, 09:04 PM
