Thread: Want to lower your car? Look in here!!
Page 23 of 29 FirstFirst ... 132122232425 ... LastLast
Results 441 to 460 of 575
  1. #441 Re: Want to lower your car? Look in here!!
  2. #442 Re: Want to lower your car? Look in here!!
    antioch ill
    i knew the eibachs were progressive not linear. I really know nothing about valving and jazz. ive been trying to learn it all but it seems to be one of those things ill understand once i do it
  3. #443 Re: Want to lower your car? Look in here!!
    Sep 2013
    California
    Hey guys I've been looking thru the forum and I didn't see a spring that can take the car down about 2" or a little more and have a good load rate... Anyone got any ideas???
  4. #444 Re: Want to lower your car? Look in here!!
    GTX Level Member blackflag's Avatar
    Virginia
    ssc's bring it down about 2" and the rides not awful. Id just go with eibachs and gr-2's though.
  5. #445 Re: Want to lower your car? Look in here!!
    SSC's will only go maybe 1.5in, and that will take many miles for the springs to settle.
    Your better off with a different spring or coilovers.
  6. #446 Re: Want to lower your car? Look in here!!
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    Eibach's and AGX. Yuss or nao?
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  7. #447 Re: Want to lower your car? Look in here!!
    Florida
    Yes. Will make for good times.
    Side note, my SSC's dropped me a little over 2" and ride pretty decent. Obviously the ride isn't stock, but it's not too shabby.
  8. #448 Re: Want to lower your car? Look in here!!
    Nov 2012
    Madison
    I'ld highly reccomend a SSC route for a first time dropper, like me. Easily a close to 2" drop like Machinegun said. On 90,000 FE3s and smooth..semi-
    Stock feel
  9. #449 Re: Want to lower your car? Look in here!!
    Jul 2013
    Antioch, CA
    Quote Originally Posted by WhiteLightningGTP View Post
    Yes, that is the plan for mine. I did the math, and while a little pricey, it should be better in the long run.
  10. #450 Re: Want to lower your car? Look in here!!
    Virginia
    Mine went a little below a 2" drop.
    If your going to spend the money on agx's I would agree the coilover route would be a good choice.
  11. #451 Re: Want to lower your car? Look in here!!
    Nov 2012
    Frankenmuth, MI
    I figure- $150 for AGX's. $250 for Springs, and under $20 for antipogo warshers. I've never seen coilovers nearly that cheap
  12. #452 Re: Want to lower your car? Look in here!!
    You may want to do some research the agx blow out quick when lowered. The cheaper gr2 seem to hold up slot better and are ***cheaper**
    04 Comp G.
  13. #453 Re: Want to lower your car? Look in here!!
    So $850...then they blow out and your out if money.
    Or maybe what $250 ish for gr2.
    Or my option
    Make your own coilovers and save moolah
    04 Comp G.
  14. #454 Re: Want to lower your car? Look in here!!
    My SSC's aka the ones I bought straight from canuck motorsports only got me around 1in so far. Either its a "bad" set or I just don't drive enough to break them in lol.
    I run KYB GR-2/SSC combo.
  15. #455 Re: Want to lower your car? Look in here!!
    Jul 2013
    Antioch, CA
    Or my option
    Any instructions for making your own coil covers?
  16. #456 Re: Want to lower your car? Look in here!!
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by Grindal View Post
    Search, there's several threads with writeups in them
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  17. #457 Re: Want to lower your car? Look in here!!
    Sep 2013
    California
    All of you guys got good ideas. This is not my first time dropping my car I kind of did it a cheap way and now I have to go back thru and redo everything. And also the gr2 are $203 from kyb web Page....
  18. #458 Re: Want to lower your car? Look in here!!
    Virginia
    Thats $870, might as well spend the little extra.
  19. #459 Re: Want to lower your car? Look in here!!
    Virginia
    maybe i just got a low set. idk
  20. #460 Re: Want to lower your car? Look in here!!
    Arizona
    coilovers run about 175-200 for everything per axle so just add that to the strut price. if you wana pay for helds or something like that than youll have to pay to play on that
  1. About the Lower intake & S/C
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2009, 03:39 PM
  2. rear end lower
    By 52 picup in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:54 AM
  3. how to lower?
    By 89prix in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2008, 07:17 AM
  4. Lower
    By 98GPGT in forum Brakes/Suspension/Chassis
    Last Post: 10-14-2008, 07:45 PM
  5. Lower KR ?
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2008, 09:04 PM
