Thread: Want to lower your car? Look in here!!
Page 19 of 29 FirstFirst ... 91718192021 ... LastLast
Results 361 to 380 of 575
  1. #361
    Get one of those cowls hoods and never have to worry about clearance B-) check out Spartans thread he had issues and needed to get those cradle spacers
    Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
    04 Comp G.
  2. #362 Re: Want to lower your car? Look in here!!
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    havent noticed any vibrations with the eibachs yet. i have heard that the condition of your motor mounts have alot to do with that
    97 gtp- 3.5 pulley, sd headers, autolite 104's, dhp pcm, hai, 180 t-stat SOLD
    94 skyline- drift slut SOLD
    97 rx7 fd3s twin turbo SOLD
    99 R34 skyline
  3. #363 Re: Want to lower your car? Look in here!!
    GTX Level Member blackflag's Avatar
    Virginia
    Excuss me fancy pants lol. Yup shorter dogbones are for stock manifolds...any set of headers wont allow short DB. If all else fails with the Vinnie Spacers you dont have to run the full set. You can run a half set if your having clearance issues.
    As usual you are misinformed.
    You CAN use shorter dog ones with aftermarket manifolds. Few vehicles have issues with with hitting the fan.
    Some people run them with sd's to pull the ubend up.
    Eddie, I would run the shorter dog bones with that ic.
    Links smart guy? Since apparently you still butt hurt over the whole lowball hud pod thing ehh
    04 Comp G.
  5. #365 Re: Want to lower your car? Look in here!!
    North Jersey
    take this to the pms ladies.
    i don't want to read your nancy pansy bs.
    i came here to do research.
    tits or gtfo.
  6. #366 Re: Want to lower your car? Look in here!!
  7. #367 Re: Want to lower your car? Look in here!!
    Virginia
    Link to what? I can't link hands on experience.
  8. #368 Re: Want to lower your car? Look in here!!
    Quote Originally Posted by Drunkie View Post
    Shortened Dogbones are garbage and DO NOT DO THE JOB CORRECTLY!
    Buy the Half set of Vinnie's Spacers, and DO IT RIGHT!
    Full set if you get on Intrax, and yes, you can fit a full set of spacers with 3" DP and headers, I did it.
    http://www.grandprixforums.net/lower...cers-1107.html
    *Cough* *Cough*
  9. #369 Re: Want to lower your car? Look in here!!
    What are you getting at Dave?
  10. #370 Re: Want to lower your car? Look in here!!
    Virginia
    However if you are goin intercooled like Eddie is, dog bones are more than likely the only option.
  11. #371 Re: Want to lower your car? Look in here!!
    it's easy enough to space the rear of the hood up a half inch.
  12. #372 Re: Want to lower your car? Look in here!!
    cut out underhood bracing and gain clearance.
    grind top of blower a little.
    ensure billet rails, not modded rails.
    More than a few ways to get hood clearance.
  13. #373 Re: Want to lower your car? Look in here!!
    Virginia
    A nice addition to this thread.
  14. #374 Re: Want to lower your car? Look in here!!
    Cannot tell if serious.
  15. #375 Re: Want to lower your car? Look in here!!
    Sep 2011
    Vancouver
    pretty sure he is serious. that stuff should be added to the first page
    99 R34 skyline
  16. #376 Re: Want to lower your car? Look in here!!
    Virginia
    I've never had to worry about hood clearance before so I didn't know or look into it. I'm sure I'm not the only one.
  17. #377 Re: Want to lower your car? Look in here!!
    North Jersey
    just run hoodless.
    but then again..
    if you can afford an FMIC setup. you can afford a new hood.
  18. #378 Re: Want to lower your car? Look in here!!
    Anyone running intense racing coilovers? I found a set for $400 I wouldnt mind picking up.
  19. #379 Re: Want to lower your car? Look in here!!
  20. #380 Re: Want to lower your car? Look in here!!
    I dont need a sway bar mount. Is $400 a good deal on them?
  1. About the Lower intake & S/C
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2009, 03:39 PM
  2. rear end lower
    By 52 picup in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:54 AM
  3. how to lower?
    By 89prix in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2008, 07:17 AM
  4. Lower
    By 98GPGT in forum Brakes/Suspension/Chassis
    Last Post: 10-14-2008, 07:45 PM
  5. Lower KR ?
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2008, 09:04 PM
